First post, by jwrichards
I can't figure this out.
I install MinGW-3.2.0-rc-3.exe on d:\
then install MSYS-1.0.9.exe.
So, final structure looks like:
d:\MinGW
d:\MSys\1.0\MinGW (I copied all the MinGW files here...don't know why)
d:\Msys\1.0\home\James\newcvs\
This is where I have the SDL (1.2.đ and the latest CVS with my one small change.
alright, './configure'
==============================James@BRAIN ~/newcvs/sdl$ ./configurechecking build system type... i686-pc-mingw32checking ..............................SHORTENED GREATLY...............................................depfiles commandsconfig.status: executing default commands====================================
now....I 'make'
====================================James@BRAIN ~/newcvs/sdl$ makeMaking all in srcmake[1]: Entering directory `/home/James/newcvs/sdl/src'Making all in main..................................................SHORTENED.................................................directory `/home/James/newcvs/sdl'make[1]: Nothing to be done for `all-am'.make[1]: Leaving directory `/home/James/newcvs/sdl'=========================================
Looks like it is all working okay...
now to run make install
=========================================James@BRAIN ~/newcvs/sdl$ make installMaking install in srcmake[1]: Entering directory `/home/James/newcvs/sdl/src'Making install in main...........................directory `/home/James/newcvs/sdl/src/main'......................SHORTENED..................................... Leaving directory `/home/James/newcvs/sdl'make[1]: Leaving directory `/home/James/newcvs/sdl'==========================================
looks like everything is working just fine, now onto dosbox
James@BRAIN ~/newcvs$ lsSDL SDL-1.2.8.zip dosbox dosboxsource.zipJames@BRAIN ~/newcvs$ cd dosboxJames@BRAIN ~/newcvs/dosbox$ PATH=d/msys/1.0/home/James/newcvs/SDLJames@BRAIN ~/newcvs/dosbox$ ./configuresh: ./configure: No such file or directory
now....I know I'm missing something somewhere...somehow....it may even be rightr under my nose. In a frantic search of the message boardds and various guides.........nothing I can find. I'm thinking of trying this again with M$ VS Studio 6 Enterprise instead, but I need to know what i'm doing wrong so that I don't end up in the same situation....
Any takers???
I'm setting up a webpage with all the code from the msys screen so if there's something I missed there....
uhmmm......only 640k, huh?
