First post, by tony359
- Oldbie
Hello all,
I have found this motherboard which seems to be missing a voltage regulator where the CPU is - see picture.
What should I expect from this board in terms of voltage available for the CPU? 5V only? And would it be easy to "upgrade" it to 3.3V?
From this thread I see there is a TIP31C as a regulator - but I also see many other components missing. Problems with QDI v4p895p3/smt V5.0
download/file.php?id=81979&mode=view
Any inputs?
Thank you!
My Youtube channel: https://www.youtube.com/@tony359
