First post, by cloverskull
Hey friends, I have some old gaming rigs and don't want to dedicate the loud/noisy fans, bulky PSUs, and vintage hardware to run my BBSes. I'd really like to run them on as cheap and power efficient a software as possible.
Currently I host these in DigitalOcean on VPSes which end up costing quite a bit. My basic needs are something I can run a multitasking Windows that has easy networking capabilities. Any thoughts? One thing I'm considering is a MiSTer FPGA using the oa486 core. Thanks!
Reply 1 of 7, by Meatball
It's not clear to me whether you plan to run a legacy Windows OS directly or virtualize, but I'm running pfSense on this (Windows with VirtualBox, VMWare, etc. would install fine, of course):
https://www.amazon.com/gp/product/B07KM7YY4Y?psc=1
It's been running for 2 years nearly nonstop. Networking galore, no noise (the entire case is a heatsink), and power efficient. I'm sure you can find something newer and more exacting to your requirements.
Reply 2 of 7, by cloverskull
Interesting! I think whatever solves the problem at low power consumption is ideal - right now my cloud VPSes are pretty expensive and I need to figure out a better option. Thanks for the recommendation. Are you running a BBS? If yes, care to share the telnet address? Cheers.
Reply 3 of 7, by davidrg
Raspberry Pi? Probably hard to get lower power than that. Though being an ARM processor and running Linux you'd have to use an emulator - probably still faster than a real early 90s PC though.
Reply 4 of 7, by konc
I'm doing this exactly on an HP thin client https://support.hp.com/nz-en/document/c01567702
I have changed the storage to a modern DOM to be able to accommodate windows XP and scheduled a restart every midnight to perform the necessary BBS maintenance activities and have this non-server OS do a restart. During the past 10 years only one has died. I understand the need for a Windows OS that can still run 16bit applications if you don't want to add an additional layer of virtualization.
Reply 5 of 7, by GigAHerZ
One option could be to buy an old netbook for that. They cost sometimes single-digit euros/dollars only, yet are very capable up to windows xp and depends on model, even windows 7. And as a bonus, you get an UPS with it, if the battery still holds anything. 😀
For configuration and everything, you have "built-in" keyboard and screen, yet it all takes very little space.
A little about software engineering: https://byteaether.github.io/
Reply 7 of 7, by Meatball
cloverskull wrote on 2022-06-01, 04:55:
My setup is a firewall/IDS only.
