First post, by retroboy87
Every time I try to run a screensaver I get an error message that says:
The program has performed an illegal operation and will be shut down. If the problem persists, contact the program vendor.
[Insert screensaver name] caused an invalid page fault in
module KERNEL32.DLL at 0187:bff7a125.
Registers:
EAX=00500614 CS=0187 EIP=bff7a125 EFLGS=00010202
EBX=00b57e08 SS=018f ESP=0056f0f8 EBP=0056f138
ECX=00402ab0 DS=018f ESI=00500614 FS=1297
EDX=00100000 ES=018f EDI=006577f4 GS=129e
Bytes at CS:EIP:
8b 03 a8 01 74 25 25 fc ff ff 0f 8b 53 08 03 f8
Stack dump:
0056f138 006577f4 005005a4 00000070 bff7a3a0 00400000 00500614 006577f4 00000000 0040000c 00400000 005005a4 00000000 00000000 00000b57 00000501
System Specs:
Azza KT3-AV KT133
AMD Duron 1800MHz Applebred
Nvidia Geforce FX 5500 (81.98 ForceWare drivers)
512MB SDRAM
40GB 7200RPM IDE HDD
Both DirectDraw and Direct3D are fully functional according to DxDiag.
Reply 1 of 3, by DosFreak
It's been a long time since I've dealt with screensavers, probably 20yrs but I thought the ones includes with Windows relied on OpenGL.
You could try uninstalling the video drivers (or renaming the nvidia OGL ICD) and seeing if the screensavers still work if so they likely defaulted to software opengl.
Make your games work offline
Reply 2 of 3, by Repo Man11
I would use a much earlier driver with Win98. The 56.64 is the first one to officially support the 5500, but you can use 43.45 if you force install the driver and choose the 5200 Ultra. The 45.23 is a popular choice.
Reply 3 of 3, by retroboy87
I've installed 56.64, and screensavers work now.
I'm getting a Kernel32.exe error when trying to install FFVII though.
