First post, by sofakng
I'm currently using a Rolls MX51s Mini-Mix 2 3+1 channel audio mixer but I need a few more inputs. I love the mixer but I can't even use the 4th input because it's a mono (?) XLR (?) input.
I'm looking to connect my MT-32, SC-55, RetroWave OPL3, and one or two other devices.
Can anybody recommend anything? I'd like something no bigger than the MT-32 size if possible.
Reply 1 of 2, by Shponglefan
If you only need 4 stereo devices max, you can try a Rolls MX42 Mini Mixer: https://rolls.com/product/MX42
If you need more, finding something no bigger than an MT-32 is not likely.
In rack size, there are multiple options for up to 8 stereo devices. For example:
Behringer RX1602: https://www.behringer.com/product.html?modelCode=P0DB6
ART Audio MX822: https://artproaudio.com/product/mx822-8-chann … h-effects-loop/
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 2 of 2, by jskyboo
Like Shponglefan said I like the Behringer RX1602 because of the individual mute buttons. One note though, you can remove the rackmount brackets but it leaves an open hole on both sides.
