Configure files?!
First post, by Dandel
to start off with, if you've seen Mingw32 and msys you would understand what i'm talking about... but what i'm suggesting is a few more files for configuration...
suggested files:
AutoMount.Conf -- list of automatic mounts -- should automatically mount a few spots, including the directory, C:\
AutoConfig.conf -- should work similair to the config.sys on dos.
autoexec.Conf -- same as autoexec.bat on dos.
configureD -- step by step configuration of dosbox ( very useful )
note: i'm not sure if all these things have been asked for before, but i figure it's a good idea.
and also, how do i get midi keyboards working?
Reply 1 of 1, by HunterZ
Most of the functionality you suggest in your addition .conf's can actually be added in the dosbox.conf under the [autoexec] section.
A configuration wizard might be nice, although there are some good frontends available that (from my understanding) pretty much do that.
