First post, by Blavius
I finally got to setting up my IBM ThinkCentre S50 from 2003. I picked it up a while ago, and recently found the matching monitor. It's a nice throwback to the Pentium 4 I used to have back in 2001. The only downside is that it only has two PCI expansion slots, no AGP. For sound I put in a SB Live, that I routed through the onboard to use the jack on the front panel.
My main goal with this machine is to play RTCW, COD, Q3 and UT99. The screen I has a native resolution of 1024x786, and I'd like to run at that resolution at a decent framerate. So I need a GPU powerful enough to play those games and being PCI. I looked for the fastest GPU I could find, assuming that the power of the card would somewhat compensate the slower PCI bus (I have seen comments here and there that support this notion) and give me reasonable performance to ~2001 standards.
I found a PCI Radeon HD5400 with 512Mb. On paper this 2009 card should have more than twice the performance of a 2001 Geforce 3 (2.6Gpixel/sec vs 800Mpixel/sec).
So now I have:
Pentium 4, 2.66GHz
1Gb DDR
PCI Radeon HD5400, 512 Mb
SoundBlaster Live.
The attachment IMG_2697.jpg is no longer available
The attachment IMG_2696.JPG is no longer available
I've put XP on it, and a period correct driver (8.93/catalyst 12.1).
UT99 runs horrible on D3D, put pretty good on OpenGl, with large open areas running generally around 60FPS, with dips to 40, and spikes to 160 in indoor areas. Resolution 1024, everything high. All good.
RTCW however is a completely different story, outdoor areas float around 12FPS with indoor running around 20. Weirdly, there is no real difference between 1024 and 640, high detail setting or low. This is unplayable, and very surprising as I recall playing through this game back in the day on a P4 1.7GHz with a paltry GF2MX.
So what gives? Am I just completely unreasonable on what to expect from this hardware, or should it perform a bunch better than it does? Am I using the wrong drivers? Is the card too new?
Reply 1 of 5, by bZbZbZ
I can't find any reviews of the PCI version of the Radeon HD 5450 (at least I think your card is a 5450). The specs of the 5450 show that although it has a higher fill rate than a GeForce3 it actually has less memory bandwidth. Then there's obviously the PCI bus holding it back. Granted I am surprised it's that slow at RTCW which I think is only Quake III based and as you noted should be playable on a GeForce 2 MX. Your observation that 640x480 isn't any faster than 1204x768 suggests the problem isn't the raw capabilities of the video card - there's probably a driver issue or a CPU/platform issue. It wouldn't surprise me if AMD didn't properly optimize their driver for the PCI cards, as by ~2009 nobody in their right mind would be seriously gaming using a PCI graphics card.
You might have more luck with an older PCI graphics card, like a GeForce FX or GeForce 6 series. Does the motherboard have integrated graphics? What kind of performance do you get out of that?
Reply 2 of 5, by Blavius
Good suggestion, thanks! I found some time yesterday to experiment a little bit.
First, I've pulled out the radeon and installed drivers for the Intel GMA865 integrated graphics:
UT99 (CTF-Face), lowest FPS when looking over map, 1024x768 all high
D3D - 34FPS
OpenGL - 38FPS
RTCW, all settings maximum
640x480 - 32FPS outdoor, 60FPS indoor
1024x768 - 30FPS outdoor, 40FPS indoor
Next, uninstalled the GMA drivers and put in a Quadro NVS280 I had lying around. I didn't use this at first since it's only 64Mb, compared to the 512Mb of the Radeon. It should be roughly equivalent to a FX5500. The card has a tiny passive heatsink that is wholly inadequate, especially in a tightly packed system like this. After a first run the heatsink got so hot you couldn't touch it. I added a little fan for now.
D3D - 60FPS (with some jerking when turning)
OpenGL - 60FPS, smooth
640x480 - 48FPS outdoor, 90FPS indoor
1024x768 - 35FPS outdoor, 60FPS indoor
These results at least make a lot more sense. Even the integrated graphics performed better than the radeon, so there is definitely something iffy going on with that. The performance with the NVS280 is definitely going in the right direction, but seems limited by its 64Mb at 1024x768. Ideally I'd like to have a card with 128 or 256Mb in the FX or GF6 series, but for now this is passable (I can always play in 640 of course).
Reply 3 of 5, by Blavius
What a bit of luck, I came across the website of a local computer recycler that had a PNY GeForce 6200 PCI - 256Mb, for 30 euro's.
The attachment IMG_2732.JPG is no longer available
This card should be in the sweet spot of power vs compatibility. With a newer driver, I tried the same benchmarks again:
UT99:,CFT-Face, 1024x786 all high
OpenGL: 60fps
D3D: 60fps
640x480: 60fps outdoors, 91 indoors
1024x768: 47fps outdoors, 70 indoors
With the 47-70fps I now get in RTCW, it is definitely playable. So, mission accomplished!
It was fun pushing this PCI-only machine to do some early 2000's gaming, but I'm not sure I would recommend it. Trawling my local craigslist yielded only three actual PCI cards, with hundreds being wrongly labelled PCI-e cards. Early PCI-e cards are really in the 'junk' phase of the price curve, starting at only a few euro's. AGP cards were also still around, but getting thin. Good thing with AGP is of course that you can work with the top-end cards, rather than the bottom of the rung stuff they used for PCI.
Reply 4 of 5, by bZbZbZ
Nice find. I'm glad you're getting the results you wanted!
I agree, a PCI-only machine is generally a constraint that is tolerated due to form factor (eg your case matches your monitor and keyboard and it would be a shame to break that apart). There were very few PCI graphics cards with good 3D performance, and it's not like you're going to buy a Voodoo 5 5500 PCI these days...
Reply 5 of 5, by swaaye
I don't think it has anything to do with the card's performance.
Try renaming the game's exe to quake3.exe. That sped it up tremendously on a HD 5770 I played it on years ago. It was getting ~20 fps too. Basically ATI used app profiles that activate based on executable to configure compatibility aspects and RTCW was not something they tested anymore.
With PCI and a card with 512MB VRAM I think the bottleneck that is a concern is geometry saturating the bus. So the more advanced the game the worse that will get. 512MB VRAM is certainly enough texture storage for anything you would run on a HD 5450.
You might want to keep an eye on temps. Those passive coolers are often barely adequate and it might thermal throttle. I don't like em.
