Olivetti M280 setup disk
First post, by Unite
Would anyone have a copy of this?
I've been working on an Olivetti M280 and have it up and running but without the disk I cannot access the bios to setup the HDD etc.
On my other olivetti systems (granted they are newer systems) clearing the CMOS or changing the hardware (pull out the floppy cable for example) would drop you into the bios or pressing ctrl shift alt del would too but on this neither works.
I'm a bit stuck without it and Google doesn't turn up much. Archive.org has everything for this system other than the software so any help would be appreciated.
Reply 1 of 2, by Unite
I got sorted, gsetup.exe let me setup the bios. Machine is now booting correctly.
Reply 2 of 2, by Irinikus
Unite wrote on 2022-06-07, 09:09:
Confirm that this is your video?
https://www.youtube.com/watch?app=desktop&v=OYfipSXdFN8
Thanks for the info regarding gsetup.exe, I've just downloaded it!
I have the same type of machine which I still need to get around to playing with!
https://youtu.be/4wDZ20otwAk
Mine's fitted with an additional ISA Memory card as well as a Math Co Processor and I would also like to fit it with a Super VGA card
YouTube
