First post, by T4600C
I got a Compaq Deskpro with a COMPAQ 232567-101 370 Motherboard, a Coppermine 1Ghz Pentium 3 (SL52R), 512Mb PC133 ram and a GeForce 4200 Ti.
Operating system is Windows XP on a 120Gb hard drive
The things I would like to upgrade is the cooler to a larger one with a quiet Noctua fan and the processor to something like a 1.4Ghz Tualatin.
1.58 MiB
1.27 MiB
Currently it has a very tiny cooler with a 50mm fan, I think there is room for something a bit larger.
I do think these 70/80 coolers could just about fit, then I may replace the fan with something from Noctua.
Perhaps replace the case and PSU fan too.
I read that Tualatins have a core voltage of 1.45 while coppermine uses 1.75, and also slightly different pin layout?
So it would not be possible to install a Tualatin into the compaq mobo?
Reply 1 of 14, by Oetker
You could check the part number of your VRM chip to be sure, but Coppermine compatible VRMs will support Tualatin voltages. Depending on your motherboard chipset you could need an adapter to make Tualatins work, or you could mod the socket or buy a pre-modded Tualatin chip. Finally there's a chance your BIOS will refuse to boot with the a Tualatin installed, but I've had good luck with an older Compaq mothrtboard.
Reply 2 of 14, by Con 2 botones
Is it a "DeskPro EN PD1050"?
If so, Tualatin is compatible:
[Solved] Help: Compaq Deskpro EN (PD1050) Tualatin BIOS rom
Mine also came with 1Ghz Coppermine from factory.
Reply 3 of 14, by T4600C
Con 2 botones wrote on 2022-06-06, 20:25:
Is it a "DeskPro EN PD1050"? […]
I think mine is a bit older than yours. Last bios update is 2.04 from 2001.
Motherboard is a 240762-001 looks like they were mostly put in Deskpro EX systems with a P3 500-1000mhz.
1.76 MiB
722.84 KiB
711.93 KiB
Reply 4 of 14, by Con 2 botones
I see your BIOS version is slightly different.
But, take a look at the fourth line printed on the North bridge, that´s what really matters:
Reply 5 of 14, by T4600C
Con 2 botones wrote on 2022-06-07, 19:31:
I see your BIOS version is slightly different. But, take a look at the fourth line printed on the North bridge, that´s what real […]
The chip has written SL5NQ.
Does this automatically mean it supports every tualatin even the fastest one? Bios would need to support it too.
V 2.04 was the most recent one I could find and the rompaq doesn't provide an update for it. 2.04 is dated 2001.
Reply 6 of 14, by Oetker
For the cooler, it's best to go with one that hooks onto both 'hooks' that protrude from each side of the socket. Also, as Tualatins have a heat spreader, you might need to bend the cooler's spring bracket a little so there's less tension. Installing a better fan is a great idea, on my machine I only had space for a cooler with a 60mm fan, but even Noctua's 60mm fan is inaudible.
Reply 7 of 14, by TrashPanda
T4600C wrote on 2022-06-07, 22:18:
The chip has written SL5NQ. […]
The 1.4s came rather late into the cycle so not a lot of boards supported it even if they supported the earlier models, most could be made to support the 1.4s by a BIOS update others need more exotic methods such as modding the BIOS.
There were also Tualatin Celerons which also fall under the Tualatin supported monkier and they had far wider support, a Tualeron 1400 is a nice CPU honestly and even if you cant get a 1.4s running the Tualeron might work instead.
Reply 8 of 14, by PC Hoarder Patrol
Seem to recall reading somewhere that these boards were actually Intel OEM, done for Compaq, and that they had the later revision Harris HIP6004B series chip to support voltages down to 1.3V ie Tualatin-capable. What does the circled chip read on your board?
312.74 KiB
BIOS-wise I can't finf anything later than 606P0 v2.04 from 2001, and the notes for this ROMPaq update certainly mention some level of Tualatin support - ftp://ftp3.hp.com/pub/softpaq/sp18001-18500/sp18124.txt
sp18124.txt
3.45 KiB
40 downloads
Reply 9 of 14, by T4600C
PC Hoarder Patrol wrote on 2022-06-08, 09:40:
Seem to recall reading somewhere that these boards were actually Intel OEM, done for Compaq, and that they had the later revisi […]
sp18124.txt
Yeah 2.04 was the latest I could find too.
90.01 KiB
H1P6004ECB
P0127ADHV
Reply 10 of 14, by T4600C
Replaced two of the three fans with Noctua.
70mm and 80mm coolers should arrive soon, will be buying the appropriate fan when I know what fits.
712.29 KiB
So a 1,2ghz tualatin would probably work and a 1,4ghz might? At least with the normal 2,04.
But with a hex editor the ROMpaq file could be edited to include 1,4Ghz?
Reply 11 of 14, by T4600C
Received the 80mm cooler! Just about fits.
Installed 80mm cooler compared to older and much louder one:
1.25 MiB
Reply 12 of 14, by Tetrium
T4600C wrote on 2022-07-07, 19:10:
That's a huge difference indeed! 😜
Btw that old cooler you have is something of a strange one. Iirc if you start taking it apart the fins should actually kinda fall off. It's not a solid cooler, it's like the fins are a folded sheet of metal which is shaped to go around the metal core of the heatsink and is kept in place by the plastic that is surrounding the heatsink.
Just so you know, should you ever decide to want to reuse that heatsink for a pentium 1 or something and start taking it apart for a good clean.
It should also be really light.
But anyway, if you ever decide to take it apart for whatever reason, don't be surprised if it stats falling apart because it's kinda supposed to 😜
Or at least if it is indeed the same one I encountered once or twice.
My retro rigs (old topic)
Report spammers here!
Reply 13 of 14, by T4600C
Received the 1,4Ghz tualatin and it works!
1 MiB
1.82 MiB
Reply 14 of 14, by Grem Five
T4600C wrote on 2022-07-29, 12:15:
Awesome... not all Tualatin boards support the 1.4, I got a Gateway Tualatin board that has no problems running a 1.4 celeron at 1.5 v but when I try a 1.4 p3 it says it cant support it because of voltage which is a pain as I know 1.4 p3 has no problems running at 1.5 v.
I see your 1.4 has a compaq sticker on it, if you got it from ebay I hope you were one of the lucky few that got in on that seller that had a bunch of them for $9.99 before those dirty profiteers got in and bought up all the stock just to resale them on ebay a few weeks later for $75 a pop.
