First post, by Nemo1985
Hello fellow vogonians.
Today I received this video card and due to bad packing has been damaged during the transport.
One of the smd caps 470uf 6v has come off and a small filter cap was around the box.
I'm pretty sure I will have to change the bigger one but I doubt I will be able to find the right place for the smallest one.
Is there anyone with such card that is willing to take high res picture so I can try to check where it is missing?
Pictures: https://imgur.com/a/hoKjR9F
Thanks
Reply 1 of 4, by sdz
Hello,
If you post some clear high res pictures of your card we might be able to tell where the cap goes.
Edit: there is another damaged cap near to the sticker.
137.54 KiB
Reply 2 of 4, by Nemo1985
Great catch, you are right this cap is loose.
That's the best I could do with my phone:
https://imgur.com/a/pmbT4zs
Edit the loose filtering caps has come off, it's the very same dimension of the other one.
Reply 3 of 4, by sdz
There are some other weird looking things, but can't really tell much from those photos. Do you have a flatbed scanner?
If you plan to solder back the loose caps, measure them first for shorts.
Reply 4 of 4, by Nemo1985
sdz wrote on 2022-06-08, 00:50:
I haven't the skill to solder back those caps.
I tried to use the flatbed but I never got good results from it, here are the pictures of the back of the card (I do wonder if my scanners sux or what):
225.69 KiB
Took another picture of the back with phone:
1.23 MiB
