First post, by sofakng
I'm trying to run Adlib Tracker 2 under DosBox-X but I'm getting the following error:
Warning: cannot open swap file c:\cwsdpmi.swp
ERROR(1) - Insufficient memory!
Can anybody help me?
Reply 1 of 1, by Gmlb256
I don't see any reason why you would need to run AdLib Tracker II on DOSBox (let alone on a fork which you should ask here) as that program it is available for both Windows and Linux (unless you're running macOS).
