First post, by craziej2k
craziej2k
Offline
hi all,
I Finally managed to get Theme Park to install in DOSBox using D-fend, I copied the CD to my hard drive and installed it from there but I can't change the settings for the sound card, language etc. I select the options and choose save but when I load up the game it doesn't notice the changes. And to top it all off the mouse doesn't work! 😒 I'm using XP with a Vinyl AC'97 soundcard if that helps. I searched the forums but couldn't find anything that works plus I'm a newb at DOS.
