First post, by mb2033
nothing to see, move along
Reply 1 of 2, by Horun
According to one manual I found it does not mention Commadore mode. It does mentions Switch 1-6 with "standard mode" for Epson LX-800 or "IBM mode" for IBM Proprinter II.
sorry is all I could find on a quick search...
Reply 2 of 2, by PC Hoarder Patrol
Although you say you've got both cable types - PC & Commodore - can you confirm which the actual printer is, either Parallel Type (8 + 4 position DIP switches) or Commodore Type (single 10 position DIP switch)
98.93 KiB
Have a look thru the Technical Reference / Maintenance manual and see if that's any more help than the User Guide
Star DMP NX1000_LC10 TechRef.zip
2.53 MiB
32 downloads
