First post, by NarakuITA
I need help, as I do not understand the behavior that presents itself in front of my eyes, somewhat strange! I bought a CF-IDE40 Converter Card Module adapter with a 32GB Compact Flash CF.
Once the components and windows 95C were installed on my IBM 330 6577 machine, I enabled DMA. However I noticed something strange, windows seemed slow to start up and shut down, like applications to start up. In fact, the Compact Flash CF is slower than the mechanical disc!
The Compact Flash sees it as compatible and has allowed me to enable DMA.
So I did some tests, these are the results:
I took a look at the bios and found DMA resources. Only in Channel 2 there is System Resources, for everything else there is only the wording available.
Why this problem?
