First post, by jewesta
Hello everyone,
this is a follow-up to my question on how to dump the BIOS of Amstrad XTs.
I ended up using DEBUG to get the dump and now I have one single .bin file (16k). I'm on a Mac and I was looking for an easy way to split the .bin file into two separate Lo/Hi files. Terminal (bash script) came to mind. I'm not a wizard on the shell so I did extensive googling and trial-and-error. This is what I came up with:
#!/bin/bash# Inspired by:# https://www.unix.com/shell-programming-and-scripting/130940-split-file-into-chunks-low-high-byte.html# Splits binary file into low and high. Usage:# ./bios_split.sh lohi.bin# Result: lohi_lo.bin lohi_hi.bin# file name without the pathfilename=$(basename -- "$1")extension="${filename##*.}"filename="${filename%.*}"# create a to-ascii + to-binary pipeline and then add "cut -b 1-2" in the middle.xxd -p -c 2 -u $1 | cut -b 1-2 | xxd -r -p > "${filename}""_lo.""${extension}"# same as above but start at byte 1 (-s 0x1)xxd -p -c 2 -u -s 0x1 $1 | cut -b 1-2 | xxd -r -p > "${filename}""_hi.""${extension}"
I could verify that my DEBUG dumps, split into hi/lo, matched some hi/lo dumps I found on the internet. So unless the person dumping these used the same faulty method, this should work.
Now I am looking for a piece of code that does the opposite. Obviously I don't need it in case of my Amstrad dumps because they are already in merged form. But I have a few 286 boards and I would like to create merged versions for these (for readability).
Again, I am not a bash expert. The best I could find was this method:
#!/bin/bash# Merges low and high bios files into one file. Usage:# bios_merge lo.bin hi.bin > lohi.binexec 3< $1exec 4< $2while IFS= read -n 1 -sru 3 HidoIFS= read -n 1 -sru 4 Lo || break[ ${#Hi} -eq 0 ] && printf "\x0" || printf "%s" "$Hi"[ ${#Lo} -eq 0 ] && printf "\x0" || printf "%s" "$Lo"doneexec 3>&-exec 4>&-
This sort of works and the merged file looks OK at first in a hex editor. But I found that if I compare my original dump to the recombined dump created using this method, the hashes don't match. So there must be something going wrong. I've attached four files: An original DEBUG dump. The hi/lo versions created with the split script in this post. And the recombined version created with the merge script in this post. Both complete dumps look like they are the same, but they are not.
Could someone pleas help me with this?
Thanks
Jens
