First post, by PDXTony
Hello fellow awesome people!
I'm beginning a 486 build and would greatly appreciate your help.
For fun, I'd like to put the maximum capacity of 30-pin SIMM memory this motherboard supports, which is 128mb.
The motherboard is a BEK-V409, detailed on this page:
https://stason.org/TULARC/pc/motherboards/B/B … 6-BEK-V409.html
I've Google'd a bit beyond that and found all sites referencing this motherboard indicate a maximum about of 128mb using two sets of four 30-pin SIMMs at 128MB (8 sticks of 16M x 9).
With that said, mind helping me choose what has the greatest chance of being compatible?
Also, some specific questions if I may please:
Does the '16M x 9' spec mean that I must choose 9 chip modules? Or am I misunderstanding that?
What about voltage and latency speeds?
Anyone know if this motherboard supports parity or only non-parity?
Thank you very much in advance!
Tony
Reply 1 of 19, by jakethompson1
Just so you're aware, no more than the first 32MB (or at most 64MB if write-through or always dirty write-back) of RAM would be cached, and Windows allocates from the top down, so the uncached memory would be used first. In addition, if you're using an SVGA VLB card with a linear framebuffer, you would want to make sure it can map it very high in memory and that the board and card is actually wired with address lines to map it beyond 64MB. More on that here: https://www.xfree86.org/3.3.6/cirrus5.html#5
Personally, I would use a PCI 486 system, or a later era VLB board like an SiS 471-based one, if I wanted to max out memory that high. Plus, 128MB in 72-pin will be much cheaper than 30-pin, since most of what you're paying for is shipping and the labor of testing by the piece at this point.
16Mx9 is referring to 8 data bits and one parity bit. It doesn't mean it needs to be 9-chip memory. The difference between 9-chip and 3-chip has something to do with how it is refreshed, I believe. You can search mkarcher's posting history for a detailed description of this as he is very good at explaining such things, or he or someone might jump in. IIRC anything 486-era supports 3-chip.
It would surely be 5 volts FPM; don't think you can find 30-pin in anything else easily, and you won't find faster than 60 nanoseconds without jumping through hoops.
You can look in the BIOS for an option to disable parity check. If you don't have it working yet, you could try finding the BIOS image or reading it, and booting it in PCem. It could be hidden, which would be annoying. Ideally it's already off by default.
Reply 2 of 19, by PDXTony
Thank you very much for the detailed information!
I'm going to start by trying: 64MB (4 X 16MB) FPM PARITY 60NS SIMM 30-PIN 5V 16X9 MEMORY RAM
I didn't know about the memory capacity to cache ratio. The motherboard has 256k of cache and I plan to run it in write-through mode.
I'll report back here with some results!
Reply 3 of 19, by maxtherabbit
I'd like to kindly direct you to the listing for your board on The Ultimate Retro
https://www.ultimateretro.net/en/motherboards/1041
Please stop linking to stason. UR is a community project run by guys from this very forum
Reply 6 of 19, by TheMobRules
maxtherabbit wrote on 2022-06-29, 19:45:
PDXTony wrote on 2022-06-29, 19:39:
maxtherabbit wrote on 2022-06-29, 19:37:
OK now I am curious why it matters. Did Stason do something bad?
Not really, just don't loike em simple as
I think the "Don't let your bike seat ruin your SEX LIFE" book ad is bad enough to avoid Stason like the plague 😛
Reply 7 of 19, by PDXTony
TheMobRules wrote on 2022-06-29, 20:00:
I think those ads base themselves off your browsing history, good sir... 😉
Reply 8 of 19, by TheMobRules
PDXTony wrote on 2022-06-29, 21:51:
Nope, my ad blocker prevents that 😉 , those are fixed ads of books written by Mr. Stason himself. Just take a look at the homepage, he has all kinds of weird stuff besides the "PC Info" section which, if I'm not mistaken, he lifted entirely from "Total Hardware 1999". That's a very good reason to use Ultimate Retro (or fall back to TH99 if necessary).
Reply 9 of 19, by maxtherabbit
They don't we all see that same bullshit
Reply 10 of 19, by PDXTony
😀 OK ok ok - got it - AND...I even contributed some pictures and a BIOS dump to: https://www.ultimateretro.net/en/motherboards/1041
Reply 11 of 19, by jakethompson1
PDXTony wrote on 2022-07-03, 01:56:
Have any luck with the RAM?
I believe the UM491 does not support robbing a bit from the tag RAM to use as the dirty RAM. So your cacheable area is indeed 64MB, and likely "always dirty" as there is no dirty RAM that I see. You can use CACHECHK once you get it going to see. On my 486DX2/80 UM491 board, I get 16 us/KB for L1, 20 us/KB for L2, and 37 us/KB for RAM.
Reply 12 of 19, by PDXTony
jakethompson1 wrote on 2022-07-03, 02:01:
Hey! Yes, the 64mb of memory I ordered works perfectly in the board. Tonight I plan on running CACHECHK and a few other utilities to ensure it's stable.
Reply 13 of 19, by rasz_pl
There is almost nothing(*) that runs great on 486 and requires more than 16MB of ram, but there is plenty of things that go wrong with more like already mentioned caching and linear VESA buffer access.
* linux proxy/local file server in 1994?
Reply 14 of 19, by PDXTony
Done!!
The attachment PXL_20220712_004103973.MP.jpg is no longer available
Reply 15 of 19, by karakarga
If I were you, I will choose a 72 pin fast page memory. They are a bit faster, around 25 MB/s.
It is nearly impossible to find a VL-bus based graphics card, as well as Isa. If you are lucky, those can only have 1 to 2 MB video ram. With 1 MB you can use 640 x 480 (or 640 x 400) 24 bit, 800 x 600 16 bit color, with 2 MB you can use 800 x 600 24 bit, 1024 x 768 16 bit, to use 1024 x 768 24 bit you need a 4 MB one as you know. But, if you have a PCI based 486 mainboard, you can easily find a graphics card up to 32 MB with 2D and even 3D acceleration. (If, not Voodoo or S3)
Reply 16 of 19, by rasz_pl
Fast page memory is the normal standard 72pin simm dram. The other kind would be EDO, rarely supported on 486. Third non option was BEDO, standard that failed in the market.
Reply 17 of 19, by mkarcher
PDXTony wrote on 2022-07-12, 00:45:
Done!!
That picture shows clearly that all 64MB is cached. If the BIOS offers "memory relocation", I recommend disabling it in this configuration. It might push a small amount of memory (like 128KB) over the 64MB limit, which might be uncached or (even worse, but unlikely in your) mis-cached. In contrast to the 64MB you have, the extra 128KB isn't worth the trouble it might cause. I own a board with the predecessor chipset, the UM480 (consists of the 82c481 and 82c482), which supports up to 32MB. The manufacturer (Elitegroup...) omitted one technically required jumper for the cache size configuration causing mis-caching when the full amount of 32MB is installed and relocation is enabled.
Reply 18 of 19, by jakethompson1
mkarcher wrote on 2022-11-23, 21:43:
Done!!
I also found a bug in the Trident 9440 VLB video driver for Windows 95 when it was trying to determine where to place its linear framebuffer. On a UM491 system with 32MB and memory relocation enabled, the tests it performed to determine whether RAM might exist at 32MB somehow passed, and it attempted to locate the framebuffer there, causing the screen to scramble right away. Disabling relocation (and then turning it back on but patching the driver) fixed the issue.
Reply 19 of 19, by Disruptor
I had a problem with a Cirrus VLB graphics card when memory size was above 48 MB.
