First post, by lowlytech
I was taking this NEC multisync II monitor apart to recap it and when I was taking the top metal shelf off it instantly fell the moment the screw came loose and it scraped off part of the anode cap paint. Is this something I should try to apply like touch up paint with a car? Or is this going to not make a difference one way or another.
Thanks
The attachment 20220702_120653.jpg is no longer available
Reply 1 of 3, by pentiumspeed
I used high voltage dielectric grease. Some come coated with this. Back in the day when CRT was common this what I used.
Cheers,
Great Northern aka Canada.
Reply 2 of 3, by lowlytech
Thanks for the info pentiumspeed. So just apply this grease to the compromised area, or should I just coat the whole area. Also any suggestions on a trustworthy brand?
Reply 3 of 3, by pentiumspeed
Permatex dielectric grease available from any automotive stores. Works well. Was used on spark plugs to prevent rubber boots from sticking and keep them dry.
Cheers,
