First post, by Al_bundy
Hi,
I set the Radeon 9600 Pro as my favourite videocard and I have a Sockel 478 Mainboard.
Actually it works a P4 Northwood 2 Ghz on it. I have a big bottlneck or is it acceptable?
I didnt find a database to calculate the bottleneck. I prefer to replace the 2ghz CPU to a Pentium 4-m 2.4ghz (mobile)CPU.
Because, i need a very low TDP ( no space for a good coolingunit)
Thank u and best regards Marc
Reply 1 of 2, by agent_x007
If you can play games at what you consider playable framerates, and visual details aren't too far from reviews from 2003/2004 - it should be fine.
Faster CPU is nice but make sure your board supports it before buying.
Reply 2 of 2, by zyga64
I remember that HP Compaq NX7010 laptops used Pentium 4 2.8GHz processors (Nothwood 533Mhz FSB). So if the laptop cooling somehow managed to do it, your desktop should be able to do it too.
The question is whether your headboard supports FSB 533 ?
As for Pentium 4-M support, it can be worse (for example, that NX7010 did not recognize such a processor). But you won't be convinced unless you try to do it...
8088@8 /640k /Genoa CGA /TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
