First post, by Return 0;
Hello everyone,
Do You know what type is the BIOS memory in this card? Trident TGUI 9440 VL-Bus, Is it 25c256 EEPROM? I found ROM dump on this site and I do not know what type of ROM can I use.
THank You.
Reply 1 of 2, by zyga64
If its size is 32kB then 27(c)256 eprom or 28256 eeprom or 29c256 flash should be ok. AFAIK they are pin compatible
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-3+@400 /64M /Rage Pro PCI /ES1370+YMF718
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 2 of 2, by Return 0;
Thank You,
Dziękuję.
