First post, by Kahenraz
I have some cheap Radio Shack floppy disks from the very late 90s. They've never been that great or reliable, but have been fine for basic things like boot disks and other temporary use.
One of the disks I have was formatted as a Windows 98 boot disk. It's been fine for years with infrequent use. Recently, I used it to boot my machine a couple of times. Then at some point it stopped being able to read some files. No problem, I thought. I'll just format it again and make a fresh copy.
When I format the disk using "format a:", it succeeds. But it struggles at around 80% (the drive gets louder and it makes a thunking sound a few times) no matter how many times I format it.
I can understand why a disk might not be reliable, if the iron oxide is thin or has lost its magnetic properties. But what makes a disk that does nothing but sit, rarely read, and is always handled carefully, suddenly have trouble formatting? Has the surface somehow become less pliable to magnetic fields?
Reply 1 of 10, by Horun
Yes the media is failing. Floppy disk have a finite usage/storage time. Say the disk is 20 years old and only been read about 20 or so times, that would equate to a 1 year disk read about 100 or more times IIRC....
As for just sitting: there is a lot of electromagnetic energy today that slowly helps ruin floppies: lighting strikes, cell phones and towers, cordless phones, etc and pollutants in the air too...
added: I have fairly good luck with Sony, Maxell and TDK 3.5" floppies and also 3M and Memorex branded 5.25". They all came with lifetime warranties (which means not much) but seem to last longer than generic ones (Office Depot, etc).
Am sure others have similar stories about what brands they have used that were good or bad 😀
Reply 2 of 10, by Kahenraz
I've heard that Sony floppy disks aren't actually that good. At least the ones from the late 90s. But then again, were there any from the late 90s that weren't terrible?
I just opened a sealed pack of BASF disks I've had saved. They are are stamped "assembled in U.S.A" and have a label that says "135 tpi certified". What does that mean? It does not have a date printed on the packaging, so I don't know in what year they were made.
Reply 3 of 10, by Horun
135 Tracks Per Inch, certified for High Density 1.44Mb formatted PC (or 2MB max) IIRC
Reply 4 of 10, by Kahenraz
Why does it need to be certified? It either is or it isn't. Is this important information or just marketing speak?
Reply 5 of 10, by darry
Unless the disks are physically degraded or degrading (i.e. oxide layer dettaching from the substrate, heat damage, mold growth, physical damage, etc), I would have imagined that practically anything to do with magnetization/demagnetization should be fixable by either formating or running through a bulk eraser .
Then again, I am no expert in these matters.
Reply 6 of 10, by darry
Kahenraz wrote on 2022-07-10, 01:53:
It probably means that it successfully passed whatever testing post-manufacture testing process was in place . Without more details as to testing methodology, it could mean anything from an automated test write/read process for every disk, to having that test run on random samples or to having some dude eyeball/smell the disks to make sure they seemed "OK".
Reply 7 of 10, by zapbuzz
aren't there disks with magnetic shielding?
Reply 8 of 10, by wbahnassi
It could be many things. Drive heads caught a particle (very dangerous and annoying), disk grew mold on a certain location, a magnet passed by and ruined a few clusters... I'd start first with a visual inspection of the surface on both sides under a strong light.. this will show any obvious liquid/dirt/kinks/scratches to the surface. If it's all clear, then a few full erase passes are usually enough to bring the disk back to life (around 3 passes from my experience).. after that a full unconditional format usually succeeds with 0 bad sectors.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, FDDx3
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 9 of 10, by Kahenraz
Is an erase pass something different than running format a couple of times?
Reply 10 of 10, by wbahnassi
Yes it's different. It basically sectors the disk to 1 sector each track (so 1 sector is full 360°), thus wiping the typical 15-sector metadata areas too. I do this in ImageDisk (a really nice imaging tool under DOS).
