Unreal Fatal error
First post, by haker120
Just simple as that, trying to run Unreal on my P1 233MMX with Voodoo 1 4MB I get fatal error however the game starts on safe mode where I cannot even set API Glide, it just doesn't change from software rendering, and I cannot set any other options. How to make it work?
And it crashes at opened viewport.
Reply 1 of 2, by DracoNihil
I've never tried running Unreal on a Voodoo 1 with 4MB, but very early versions of Unreal are extremely temperamental with what drivers you have installed. 225f is the highest version you should use if you're trying to use any 3dfx card whatsoever.
― Κυνικός Δράκων
Reply 2 of 2, by haker120
@DracoNihil thanks a lot, now I can even change advanced options. 😁
