First post, by Jo22
Hi everyone,
There's something that I wonder, maybe you can help?
I would like to know what ISA cards (mainly VGAs) can handle bus speeds past 8 MHz.
And if they need wait states (if you know about it) at some point.
I know, it sounds a little bit mad at first, but my first 286 PC ran at a 12 MHz FSB by default (from what I know).
The ATI VGA wonder (on-board) and the expansion cards (IDE host adapter, PAS16) did seem to handle that fine, as well.
Likewise, my current 286 runs at 10MHz/10MHz and all ISA cards are fine with it (SB2, NIC, OAK VGA, CF card).
That's why I would like to hear about your experience or knowledge. 🙂
For example, do some cards handle a 14, 16 or 20 MHz bus? With wair states, maybe?
Or is 16 MHz the very limit (twice the standard ISA clock rate)?
Thanks in advance,
Jo22
Reply 1 of 3, by Tiido
I use one late WD card (30 or 31) at 16MHz without any problems on a 486DLC machne. I think it even worked at 20MHz but then all the other cards stopped working right 🤣. Not all IO, LAN and sound cards like these higher speeds. Performance gains are quite substantial so I always maximize ISA speed.
My Trident 8900D was not happy at 16MHz, it occasionally produced garbage so it is used at 14MHz or less, I no longer remember what speeds the other cards I have managed at most and for now I cannot test them either, I'm in process of setting things up for a move (to another country).
Reply 2 of 3, by rmay635703
I was going to say that I’ve had a couple Trident cards that ran 16mhz
I had a generic ide multi-io that ran 16mhz
Network cards and Sound cards gave the most trouble
Reply 3 of 3, by Anonymous Coward
Although it would be a poor choice for a 286, the Mach64 can apparently clock pretty high. I haven't tried, but I heard 20MHz is easily doable.
