Type command with pause?
First post, by rolloLG
DOSBox has an internal Type command, to display for example a HELP.TXT ASCII file contents...
My problem is "Type HELP.TXT | more" doesn't work and won't pause the page as expected. This Type version does not have a /P option built-in, so... how can I do if I need to read (with page pause!) a simple txt file from DOS within DOSBox?
A 3rd party Type command alternative?
Upgrade built-in Type command to support /P (pause per page)?
P.S.
I have C:\DOS\MORE.COM in my path, but doesn't work to pause the page as the "fake" internal COMMAND.COM of DOSBox doesn't seem to support it. If I run COMMAND.COM from MSDOS6.22 copied to DOSBox drive (actually a Win dir mounted as a drive) I can use the " | more" trick of course....
ROG-mini-22x13.png SCAR 18 G834JY: i9-13980HX, 32GB DDR5@5600, 4090 laptop 256 bit 16GB, 2560x1600 16:10 G-Sync, NVMe 6GB/s, 8BitDo Arcade Stick, EasySMX X10 controller, ROG Strix Carry Mouse.
Reply 1 of 8, by Errius
I just use EDIT.COM in these situations.
However, this doesn't help if you want to capture a program's /? usage page, or the scrolling output of some other program. The problem isn't with MORE, but the lack of support for piping. However, the developers have said that this isn't going to be added to DOSBox because it isn't directly related to gaming.
ETA: Re: Type |more not working
Just do "more filename"
Is this too much voodoo?
Reply 2 of 8, by BloodyCactus
list.com (sometimes known as t.com) by Vernon Buerg
Reply 3 of 8, by rolloLG
After some research I've found that Less177e.zip from https://www.mmnt.net/db/0/1/ftp.cc.umanitoba. … are/pc_migrate/
seems to work fine (press 'q' to quit text view, and you can also move up/down with PgUP/Down, Home/End)
Other good source of old programs for 16-bit: https://www.bttr-software.de/freesoft/txtutil1.htm#less
Reply 4 of 8, by ripsaw8080
Rank DOSBox Author
DOSBox Author
rolloLG wrote on 2022-07-18, 18:34:
Use the redirection form (MORE < HELP.TXT) rather than the piping form (TYPE HELP.TXT | MORE)
Reply 5 of 8, by BloodyCactus
grab list.com from https://github.com/sebras/buerg/tree/master/list/9.6y1
rename it to t.com (it behaves different if its called list.com), t.com file to read a file or just t.com to get a directory list and pick a file. hex mode, colours, whatever.
in file list mode, press 1/2/3 etc to change column displayed..
its so versatile. more/less is like darkage living.
Reply 6 of 8, by rolloLG
ripsaw8080 wrote on 2022-07-18, 21:17:
Oh, nice.
Reply 8 of 8, by gerry
sebras wrote on 2023-03-27, 02:31:
Hey! It seems like collecting all of Vernon's tools in one place wasn't as pointless as I thought it might be while doing it. I' […]
BloodyCactus wrote on 2022-07-19, 00:48:
wasn't as pointless as I thought it might be while doing it. I'm
happy it was useful to someone. 😀
it's always good to do things like this - eventually someone will find it of use, spread the news and benefit others 😀
