DGVOODOO Error....
First post, by Wanderer...
I need to run DGVOODOO in Glide Version 2.11(Glide.dll) but when I click on it, I get this error "dgvoodoo is set to work as a VDD. Yoiu can not run serverprocesses" ... What does this mean and how can I fix it? I am trying to run The Elder Scrolls Adventure Redguard
Reply 1 of 3, by Zebius
If you are using Windows XP then go HERE.
Read posts #1 and #46.
Reply 2 of 3, by Gambit37
This is a Glidos forum, not a DGVoodoo forum...
Reply 3 of 3, by Glidos
Although it might be an appropriate place to get the answer "use Glidos instead".
