First post, by AST-AUTISMO
Hi,
Looking to pick up an ISA sound card with genuine OPL chip, but all the ones I see are with a volume knob sticking out of the bracket. How does the knob work? Does it replace software volume adjustment? Or is it for a headphone output for example?
Reply 1 of 3, by Jo22
Hi there! I do have an early Sound Blaster 16 with an OPL3 (CT1740).
The volume knob is analogue and part of the headphones amplifier.
It's a variable resistor, a potentiometer (aka pot or poti).
It can either work as a current limiting resistor or as a voltage divider.
The card can be jumper set to bypass the audio amplifier, though.
That will give line level output, essentially.
The software-controlled mixer is still controlling the source volume that comes out of the sound chips (D/A converter, OPL3, CD player, speaker). Or rather, the mixer chip.
I think we can see it as the driver stage that's controlled via software.
In audio applications and radio applications, such a driver feeds the amplifier.
If the driver output is lower than normal, so is the result of the amplifier.
It's like relationship of a CB radio and an linear amp, hi. ;)
Edit: Edited.
Reply 2 of 3, by kixs
There are many "newer" ISA cards with proper OPL3 - looking at Yamaha ones. Depends also on your other requirements.
Visit my AmiBay items for sale (updated: 2025-08-01). I also take requests 😉
Reply 3 of 3, by Jo22
This might be helpful :
The way to detect OPL3 clone
