First post, by Paul_V
Hi, everyone.
I'm searching for an Insyde ExpressROM BIOS file or a dump for a Geode LX/CS5536.
It is used in a variety of industrial or development motherboards, here is the copy of the guide:
http://web.cse.ohio-state.edu/~zhang.574/Xpre … 01-1%5B1%5D.pdf
Unfortunately, I'm not able to find a copy anywhere on the net.
A link for evaluation copy from the guide is long gone.
If anyone happens to own a motherboard that uses Insyde BIOS, a dump would be greatly appreciated.
Reply 1 of 17, by Horun
Hmm yeah no rom files on the archived website: http://web.archive.org/web/20060620032842/htt … esite/index.cfm
example http://web.archive.org/web/20060622070155mp_/ … RDK/EPICRDK.cfm top link to Xpressrom leads no where.
Also the Tawain website does not appear to have the rom's with a quick search: http://web.archive.org/web/20060502063707/htt … tw/en/index.asp
There are other Geode LX+CS5536 SBC, one by Jetway J8F9 has a downloadable bios but is award bios. https://www.jetwaycomputer.com/J8F9.html
Maybe someone else will have better luck finding an Xpressrom bios....
Reply 2 of 17, by Paul_V
Thanks for your time and effort, Horun.
Yes, archive links are dead too, I should've mentioned it in my post.
Insyde BIOS was also used by such brands as Kontron, Lippert, WinSystems.
Could not find any on their sites either.
I forgot to mention, that I did actually found one from the link below:
https://www.winsystems.com/product/ppm-lx800-g/
But it seems to lack the whole menu section, where you setup Multipliers and PLL clocks.
And finding an editor for that kind of BIOS is next to impossible.
I probably should also clarify what I'm trying to achieve:
Insyde BIOS has a whole section for setting up various Multipliers for CPU and GLIU.
LX architecture seems to be extremely flexible at setting clock speeds. For example, page 554 here:
https://www.amd.com/system/files/TechDocs/332 … LX_databook.pdf
Yet, I'm unable to get CPU speed below 166Mhz (33.5x5, and it works only if you also downclock memory from 200mhz to 100mhz. Without memory downclock, the lowest CPU multiplier working is 7 )
LX has a bit tricky architecture.
Reply 3 of 17, by Horun
Hmm the table on page 556 shows lowest CPU speed is 166Mhz as default by bootstrap. am no genius with these things but like other early chipsets the DRAM clock speed is co-dependent on the CPU FSB,
for the memory controller to work proper it must match certain multiplier/divider of cpu fsb or it looses Sync/Async... so if run lower CPU FSB then it also must have lower Mem clock.
According to table 6-87 at CPU 166Mhz the multiplier is 4 (so would be 42Mhz FSB iirc)... just an observation
Reply 4 of 17, by Paul_V
Horun wrote on 2022-07-30, 23:27:
Yes, and that's where DDR's DLL (Delay-locked loop) also comes into play, which prevents memory clock from going out of spec frequency boundaries.
It can be turned off, and some BIOSes even have this option.
I'm currently figuring out chipset and memory registers, will try to check some things manually if I won't find a suitable BIOS.
If it can clock lower, good. If it can't, good to know also 😀
Reply 5 of 17, by Petrozawodsky
Hello.
Maybe it helps: https://file.remont-aud.net/dumps_1/s_10-02-2 … 900_Comfort.zip
Can anybody help with ultilities for work with Geode BIOS dumps?
This bios is locked for entering to menues. Not Del, nor F1 are not worked.
I need to boot from USB-flash drive, but this BIOS is locked to boot only from the IDE-drive.
Reply 6 of 17, by Petrozawodsky
Petrozawodsky wrote on 2023-06-03, 18:47:
Hello. Maybe it helps: https://file.remont-aud.net/dumps_1/s_10-02-2 … 900_Comfort.zip […]
Hello.
Pleae, help.
Reply 7 of 17, by Paul_V
Petrozawodsky wrote on 2023-07-19, 15:08:
Pleae, help.
I'm sorry, but I'm afraid you won't get much help there. It's proprietary industrial equipment through and through.
No tools I could find would do any good, it's BIOS is probably proprietary one too.
Reply 8 of 17, by Petrozawodsky
Paul_V wrote on 2023-07-22, 13:28:
Pleae, help.
Some investigations tells that BIOS is ordinary, but tweaked.
rle.exe DOS-utility can unpack that content.
I think, it enough to find, how to change BIOS settings manually or enter to BIOS menus.
Here boot options from that BIOS: NONE, Hard Drive, USB Hard Drive/Flash Drive, USB CD-ROM Drive.
Reply 9 of 17, by hooddy
If there is anyone alive and wanna it i have two geode lx 800 bios dump. And im search a way to edit bios. To be clear a way to change some settings in one dump equal to another one.
And ya should to try shift+f8 to enter hidden settings.
Reply 10 of 17, by Nexxen
hooddy wrote on 2024-03-31, 21:54:
Whatever you have, post it here.
Thanks
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 11 of 17, by hooddy
Nexxen wrote on 2024-03-31, 22:24:
Thanks
Here it is. Its from similar netbooks based on some Chinese Malata netbooks. Different in some starting setting like splashscreen, default screen resolution and onboard keyboard.
    bios.zip
    970.06 KiB
    8 downloads
Reply 12 of 17, by Paul_V
Thanks a lot!
It's been a while, could not find where I stashed my previous motherboard (I think it was from Advantech, which is an AWARD based mobo)
But I tested both BIOS'es on some futjitsu thin client motherboard and both worked like a charm.
I also found a compatible AWARD based one with PLL settings and did some testing.
The lowest I could downclock is 166Mhz for both CPU and RAM (133Mhz CPU boots but fails to load DOS)
CPU frequency can go down only if you downlock memory first.
Unfortunately, both BIOS'es (AWARD and INSYDE) do not allow disabling memory DLL to downclock it further.
At 166Mhz, Topbench scored close to Pentium 266 MMX with cache on and 386DX@40Mhz with cache off. Still pretty fast
And did I mention native 1600x1200 resolution in DOS? Niiiice. And it does not suffer from performance issues at 1600x1200 with sierra game engines, unlike 855gm
Also Insyde XpressROM guides mention built-in OPL3 emulation through AC97 (although only GX-1 is mentioned), imagine the possibilities with the right firmware...
Maybe sometime I'll revisit the project.
I wish I could help you with editing, but my initial search did not yield much result, aside of what's already been mentioned in this topic.
There are some editors floating around the web, but they are for newer UEFI H20
If your dumps are the same BIOS, but have different settings, you could try finding and modifying those differences in dissasembler or with hex editing
Also AMD Geode seems to allow cross-flashing, which requires a donor motherboard BIOS with a matching Super I\O controller.
The last ditch effort would be asking Insyde Software directly.
Reply 13 of 17, by hooddy
Im glad it helps. About bios modding yep it may changed with hex editin. There is nothing special to do even not import export modules coz all settings is existed in both of thus dump (but splash screens so heck with it). I need just change startup defaults from one state to another - screen resolution, keyboard type and maybe ata settings to 80 conductor type and cpu clock for auto. All this presets already existed i just need to make it deafult so my netbook not requred onboard battery to store it and works fine with no attachet external perifery like monitor and keyboard.
Reply 14 of 17, by hooddy
And well no Insyde software deny in help. At least the one available e-mail at their site. Found some decompiler (which useless with no compiler and to change settings i don't need those tools i suppose) and logo reader.
And found some Insyde roms but not for Geode cpu. Dunno ya need it in here or not.
    abr2-0.16.zip
    1.82 MiB
    6 downloads
    FlashIt.zip
    28.98 KiB
    6 downloads
    insydeco.0.1.zip
    45.67 KiB
    6 downloads
Reply 15 of 17, by Paul_V
You could also try searching something like "CGUTIL congatec System Utility"
Claims to update and modify AMI / Insyde based ROMs. But only boot logo modification is mentioned for Insyde. Module modification section is probably for AMI-only
Reply 16 of 17, by hooddy
Paul_V wrote on 2024-04-06, 21:35:
Well its placed here https://www.congatec.com/en/products/qseven/conga-qa3/#tab3 but I didn't receive admin approve for registration and can't download it.
Reply 17 of 17, by Paul_V
I'm writing down this info in case someone else would need it.
After a couple days of fiddling I can more or less make some conclusions:
If you have a system with LX800\CS5536, have access to BIOS chip and nessecary tools\skills, you may try cross-flashing it with firmware from another similar LX800 MoBo.
It should work in most cases provided:
1) CPU and companion chip match.
2) Super I/O chip also matches or is compatible register-wise
3) If RAM chips are soldered, they have the same characteristics (often there's no SPD chip either and memory init comes from BIOS code)
4) Peripheral devices like LAN\PCI\VGA should work after swapping corresponding ROMs,editing PCI Tables or changing default BIOS setting for panel\resolution (Award\AMI)
5) Proprietary stuff like FPGA may or may not work, but the system should boot in any case. May also be custom PLL circuit, but I have not seen that yet.
This can be considered as a workaround for MoBo's with restricted BIOS. There's also a coreboot build for LX800, but I've not tried that.
Of course, there may be caveats. Like a non-working temperature sensor, which forces Linux installation to halt, because it reads "255" value.
My exprements mostly involved Fujitsu-Siemens Futro A220 and Advantech PCM-9375
The former successfully worked with Insyde\AWARD\AMI. W83627HF is a very common I/O chip.
The latter is a real pain, as it uses SCH3114 for Super I/O. Not many manufactures did use it. But on the other hand, there's no real need for flashing it as Advantech uses standard Award BIOS.
As for downclocking - 133Mhz is the maximum I could get, though not very stable.
This CPU cannot clock lower than memory. And memory cannot clock lower than that, because DDR DLL does not work below 125Mhz (according to JEDEC datasheet)
I tried disabling DLL (Delay Locked Loop) through MSR registers, but without any results so far. System just freezes or crashes.
Other than that - if BIOS allows you to set Manual CPU\RAM speeds beforehand, ignoring H\W straps, you can then change those settings on the fly through MSR address 4C000014h (editing MSR with AUTO setting in BIOS makes system freeze)
So, it would not be very difficult to make programm like cpuspd to set LX800 multipliers.
    91.38 KiB
