First post, by aaronwhooley
Hi guys,
I recently picked up an avance logic al sl 100 at a yard sale.
I took it home and plopped it Into an old 386 pc.
I downloaded and Installed the drivers from the driver library and all is fine - except for the fm sound.
In the test program it tests the 8&16 bit fine but when I select the fm test it’s first a loud hiss and then some of the notes I can hear but very distorted and completely unlistenable.
Is this something like an amplifier problem? I tried replacing a few of the caps near the fm chips (ls245) (Yamaha opl clone) but same result.
Anyone else ever happen to have a similar issue with a sound card? And if so, maybe you could share some experiences here? Would be great so I can try something else to try get it playing properly.
Seems like a cheap clone but it has a cool feature where it passes the pc speaker sound through the sound card. (Never had a card that did that before without routing via cables)
Here is a short video of the problem.
WARNING IT GETS LOUD! Watch out headphone users! 😀
https://youtube.com/shorts/BzQjS8F-MbE?feature=share
Many thanks,
Aaron
*My retro rig*
1994 Peacock 🦚 “Professional”
Intel dx4 100 MHz
UM8810p AIO motherboard
32MB Ram
52x CD-ROM
540 mb Quantum Fireball
AWE 32 ISA
S3 Trio 64 PCI
Voodoo 1 4mb PCI
Realtek LAN PCI
Hyundai Image Quest v770
Reply 1 of 14, by zyga64
I had exactly the same behavior.
If you have the same or similiar card to mine, just replace 74LS245 chip near LS262 chip (actually this one is YMF262 clone).
I replaced it with 74HCT245 (because I just didn't had an LS245 nearby) and FM started to sound like it should.
Two 74LS245 chips below which I desoldered were IDE CD port buffers, therefore were not necessary.
BTW, on my card in place of two capacitors below amplifier (C48 and C48) were actually soldered resistors 😀 I also replaced them based on the reference diagram.
... and added a top negative voltage regulator -9v (instead of a resistor to -12V from ISA slot) and capacitor C38.
    200.29 KiB
1) VLSI SCAMP /286@20 /4M /CL-GD5422 /CMI8330
2) i420EX /486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
3) i430FX /K6-2@400 /64M /Rage Pro PCI /ES1370+YMF718
4) i440BX /P!!!750 /256M /MX440 /SBLive!
5) iB75 /3470s /4G /HD7750 /HDA
Reply 2 of 14, by Jo22
Thanks a lot for the tipps, zyga64! 😃👍
A few years ago I encountered some audio issues with the 100+..
Maybe some of the things I found out are still helpful, not sure.
ALS120, ALS100 Plus audio fix ?
Reply 3 of 14, by aaronwhooley
zyga64 wrote on 2022-07-30, 12:21:
I had exactly the same behavior. […]
Thank you so much for the advice! Yeah I will have a look through my bin o parts and see what I can find. Other than that it’s a great card and quite clean pcm sound!
Thanks again!!
*My retro rig*
Intel dx4 100 MHz
32MB Ram
52x CD-ROM
AWE 32 ISA
S3 Trio 64 PCI
Voodoo 1 4mb PCI
Realtek LAN PCI
Reply 4 of 14, by drosse1meyer
I know this probably doesnt help you, but the ALS100+ version has jumpers to select line vs speaker level output which cuts down on the noise a bit, or at least mine does.
Reply 5 of 14, by dionb
drosse1meyer wrote on 2022-08-04, 02:01:
Word of warning with ALS100+ cards though: the "74LS245" chip there isn't a regular 74LS245 like on the ALS100 cards, it's actually the OPL3 clone itself. So if you have this sort of problem and replace the "74LS245" chip on the ALS100+ card with a regular one, you will lose all FM - and might short stuff out too.
Reply 6 of 14, by zyga64
dionb wrote on 2022-08-04, 06:41:
Yes. But only for ALS100+. On my ALS100 (not plus) card: LS245 is actually 74LS245, OPL clone is LS262 😀
BTW - real 74LS245 has 20 pins (legs), while the OPL3 (and clones) has 24 of them
Reply 7 of 14, by Thermalwrong
On my ALS200 card that's got a DIP20 chip connecting up to the OPL3's traces, it's actually called just the "LS245". Other markings on it are "7B146M1 748".
The first post goes into impressive detail, covering what pins were removed to make it work and has some other good examples of how the OPL3 DIP-version got remarked: All the truth about FM in ALS100 Plus+ cards (includes facts, tech info and tests)
Reply 8 of 14, by appiah4
Thermalwrong wrote on 2022-08-04, 14:45:
That is a fascinating thread and possibly one of the most interesting things I read on VOGONS since I signe d up.
Reply 9 of 14, by drosse1meyer
Yep, absolutely
Also, do people not like the ALS100+? I think it sounds good. ;D
Reply 10 of 14, by Joseph_Joestar
drosse1meyer wrote on 2022-08-04, 15:28:
IIRC, the "plus" version doesn't support High DMA, unlike the regular ALS100.
This can be problematic in some games like Duke3D, but there are workarounds.
Reply 11 of 14, by drosse1meyer
Joseph_Joestar wrote on 2022-08-04, 15:33:
Yea I believe I ran into this issue, had to manually edit the config file to get it to work, don't remember which game, it may have been Duke3d or ROTT...
Reply 12 of 14, by keropi
ALS100 is good but it cannot escape it's budget roots... even on the best pcb/design there are quality issues that cannot be avoided. But it sure beats something like the CT1320/CT1600 and noisy SB16s
Reply 13 of 14, by zyga64
WOW! Just WOW ! Thats a truly detailed investigation !
Reply 14 of 14, by Thermalwrong
Well that was JazeFox investigating it, the author of Unisound so it makes sense they went so in depth 😀
I've seen similar on my SB 2.0 clone card, which uses 'SC801' & 'SC802' chips, which are different pin counts but are still pin/signal-compatible with the original YM3812 OPL2 and YM3014B DAC.
