First post, by RJ8
I wonder if a DX10 to DX11 wrapper has ever been considered.
The number of DX10 games is not small and we could such a wrapper for Vorpx as well.
RJ8
Request a game profile for VorpX - VorpX Inofficial Gamelist - RJs VorpX Games
Reply 1 of 3, by TrashPanda
RJ8 wrote on 2022-07-30, 17:53:
RJ8
I’m trying to think of a reason you would need this, if your gpu supports DX11 then it also fully supports DX10 if you only have a DX10 Gpu then you can’t use DX11 at all.
AFAIA there is no gpu that supports DX11 that doesn’t also support DX10.
Reply 2 of 3, by Dege
Explanation: I think VorpX can only hook the D3D11 library (dll), so wrapping DX10 to 11 would solve the problem.
No, I'm not planning such a wrapper. It wouldn't fit into the line of the other API dll's. Or, it should support wrapping to DX12, resolution forcing, and so on, like the others which doesn't make much sense for "regular" usage.
Wouldn't it be simpler to add the support into VorpX instead? As far as I have dealt with it, DX10 is a real subset of DX11 and the only difference is in handling the reference count of the API objects.
Reply 3 of 3, by lowenz
Special K doesn't support D3D10, so a specific wrapper would be appreciated 😁
