Socket 7 build, which direction should I go?
First post, by Jasin Natael
I have on the way a Soyo SY5EMA+ board.
Provided that it works and doesn't need a full recap (even if it does eventually) I will be repurposing it as the new home for my K6-3+ build.
That said that leaves me with my problematic but somehow charming PC Chips M571 system that will need a new processor and perhaps a new video card.
It currently has my PCI Voodoo 3 2000, I will likely place my AGP v3 3000 in the new board as it is currently in my Socket 370 build that is likely going to get retired or rebuilt with a VIA chip.
But I might keep the PCI card in the PC Chips build, not sure.
So my question is this: What CPU should I use in the PC Chips board? I have a handful of socket 7 CPUs. None of them super exciting.
Pentium Classic 100mhz
Pentium 166MMX
K6 200
K6/2 350 (likely won't use any K6/2 as I have the K6-3+, redundant)
Not sure what else I might have in the spares bin.
I was also playing with the idea of a Cyrix chip if I can find one cheap enough....I have a Cyrix 5x86 in my 486 and it has been a fun chip.
I doubt a WinChip2 will fall in my lap and Rise chips are pretty much out of the question.
What would all of you do?
Bear in mind I'll likely build, bench and then never use this machine again. Such is my curse.
Reply 1 of 73, by Sphere478
Fun chip ideas and typical overclocks:
2.2v cyrix (up to 350mhz)
Tillamook 266 (up to 450 mhz)
Rise 266-366 (up to 366 mhz)
Sphere's PCB projects.
Reply 2 of 73, by Joseph_Joestar
The M571 has a very nice on-board sound card, based on the CMI8330 chip.
It's low noise and very compatible, so I would use it for DOS gaming. A Pentium MMX 166 would be a good CPU to pair with it, if you take that route.
My retro stuff
Reply 3 of 73, by Jasin Natael
Sphere478 wrote on 2022-08-03, 19:02:
Fun chip ideas and typical overclocks: […]
Good idea on the Tillamook, but I should mention that I have a Gateway Solo 2500 laptop that I upgraded from the 166 to a 266mmx Tillamook.
So I kinda feel like it is already represented.
But how hard are Rise chips to source these days? I kind of figured it was practically vaporware at this point.
Reply 4 of 73, by Jasin Natael
Joseph_Joestar wrote on 2022-08-03, 19:08:
Yes. I think that you are the one who informed me of that chip. I haven't the header unfortunately. I'm not sure on the pin out but maybe I could scour one on eBay.
The machine is currently using a ESS Audiodrive, i only have 3-4 ISA sound cards so a good onboard option would be nice.
Reply 5 of 73, by Joseph_Joestar
Jasin Natael wrote on 2022-08-03, 19:32:
The pinout for the microphone and line out connectors is available. I built myself a custom line out bracket using that.
BTW, that board is extremely well documented. A bunch of info and drivers can be found here and also here.
My retro stuff
Reply 6 of 73, by drosse1meyer
No interest in a P233-mmx?
The other chips (e.g. cyrix) seem like a fun experiment if you can get your paws on one
Reply 7 of 73, by Sphere478
Jasin Natael wrote on 2022-08-03, 19:30:
Good idea on the Tillamook, but I should mention that I have a Gateway Solo 2500 laptop that I upgraded from the 166 to a 266mmx […]
Not that hard. Watch ebay. They pop up now and then.
https://www.ebay.com/itm/363848589886?epid=13 … IoAAOSwsRBii7jc
Here is one of the 433gp core cyrix chips.
Reply 8 of 73, by Jasin Natael
Joseph_Joestar wrote on 2022-08-03, 19:41:
Ok that is good to know it can be done. I used both of those links quite a bit getting that board to behave with the K6-3+
Reply 9 of 73, by Jasin Natael
drosse1meyer wrote on 2022-08-03, 20:30:
It isn't that I don't have interest in one. It's just that I like to do something different with each build if I can.
While I don't have a pMMX running in a desktop, I do have the Tillamook 266 running in a laptop.
Nothing wrong with an Intel 233 build, it's just been done to death.
Honest if I do go that route I will likely stick with the 166mmx as I already have one and I actually had one at that speed back in the day. So I have a LITTLE nostalgia for one.
Reply 10 of 73, by Jasin Natael
Sphere478 wrote on 2022-08-03, 21:56:
Not that hard. Watch ebay. They pop up now and then. […]
Yeah I have been browsing about a little looking at them. I don't know much about them. I seem to remember they have two variants, one with a more reasonable voltage and one with like 3.2volt vcore or something?
I'd honestly like to find a working MP6 for cheap, but hey....
Reply 12 of 73, by Jasin Natael
Sphere478 wrote on 2022-08-03, 22:51:
Ah, thanks. I was a bit off on the voltages but I knew there was something of two different models.
Honestly I'm leaning towards Cyrix as they seem cheap enough and easy to find. But it's something at least a bit different.
Also my M571 isn't REALLY stable at 83mhx FSB, it will do it but locks up occasionally.
It is much happier at 75mhz FSB and that could match up nicely with a Cyrix.
Reply 14 of 73, by Jasin Natael
Sphere478 wrote on 2022-08-04, 00:18:
Overclocked you may be able to get that one I linked to 500gp level
Yeah I added it my watchlist. Pins look a little ragged but not too bad, everything looks workable.
I see a chip in the ceramic in one corner but that shouldn't be and issue.
I would assume that the 2.0v chips are better overclockers as opposed to the 2.9v chips?
Reply 15 of 73, by appiah4
It's a PCChips board, go full troll build: Early Cx6x86 with a Rage Pro and an AD1816 or OPTi931 sound card.
Reply 16 of 73, by Jasin Natael
appiah4 wrote on 2022-08-04, 14:20:
🤣 that is actually somewhat tempting! But I would have to substitute a SiS 6326 for the Rage Pro.
Rage Pro is just way to fast. HAHA
Reply 17 of 73, by Sphere478
Jasin Natael wrote on 2022-08-04, 13:10:
Yeah I added it my watchlist. Pins look a little ragged but not too bad, everything looks workable. I see a chip in the ceramic […]
Look at the back if the black square is small and voltage is low that is the one you want.
Reply 18 of 73, by Jasin Natael
Sphere478 wrote on 2022-08-04, 21:24:
Ok, that is good to know. Thank you.
Reply 19 of 73, by timw4mail
It seems like the iDragon (2.0V version) shows up more often than the originals, but that's also generally what you want.
