First post, by Riikcakirds
I can't find any search results on vogons about umbpci specifically causing games not to run, only posts saying it works.
After running around 10 different games I've come across a game that doesn't work with umbpci .sys loaded.
'Cadaver - the payoff'. With umbpci loaded the game goes to the scrolling intro screen and then pressing space bar to start the game causes a black screen crash/freeze. It works without umbpci loaded. This is in dos 6.22.
Is this a common problem with umbpci loaded? I've only used it a few months to free up more upper memory.
Reply 1 of 6, by matze79
Can you also try it on another Computer with umbpci loaded and reproduce the result ?
Reply 2 of 6, by Jo22
I wonder the same. UMBPCI is quite hardware-dependent, it only works with known chipsets.
"UMBPCI makes UMBs from disabled memory that is intended as Shadow-RAM. UMBPCI enables this memory and disables its write protection. "
But that doesn't correctly work on all hardware.
486 era VIP (VLB/ISA/PCI) motherboards are know to be troublesome, if memory serves.
https://www.uwe-sieber.de/umbpci_e.html
Reply 3 of 6, by maxtherabbit
Riikcakirds wrote on 2022-08-04, 16:52:
I can't find any search results on vogons about umbpci specifically causing games not to run, only posts saying it works. Afte […]
Which regions of the UMA specifically do you have UMBPCI enabling?
Reply 4 of 6, by Riikcakirds
maxtherabbit wrote on 2022-08-04, 20:32:
Stepping through config.sys, umbpci displays the message:
Umbpci V3.90
Using - CC00-DFFF
Chipset 430FX.
From the above than range is around 80KB
Another problem I noticed, playing the game (by not loading umbpci) and then exiting to dos by pressing cntrl+c. Then in dos just typing a few dos command like MEM will crash Dos itself. Pretty strange, never seen a problem like this before.
Reply 5 of 6, by Jura Tastatura
Riikcakirds wrote on 2022-08-13, 13:52:
Stepping through config.sys, umbpci displays the message: Umbpci V3.90 Using - CC00-DFFF Chipset 430FX. […]
Umbpci V3.90
Using - CC00-DFFF
Chipset 430FX.
I think that's not correct range for 430XX, 80kb seems too much for this chipset. I'll check later on my retro rig what's the working range and will post when I get back home from work.
Reply 6 of 6, by Jura Tastatura
I go with /I=E000-EFFF range in my config.sys, read somewhere before it's a safe range for 430XX chipsets and it's the only combination I had no problems with. Don't think you can squeeze more out of it. If you can, please do tell me. 😁
