First post, by kawe-dus
Hello,
I own an Shuttle Hot-307 mainboard wich is equiped with four W24256AK-20 Chache modules wich filled 1 / 2 Banks.
The mainbord is equiped with another two smaller (dip22?) sockets for TAG Cache Modules. This two
Sockets are unpopulated at my mainboard.
The mainboard will only start when i dissable the caching function in the bios (i think because
The missing tag modules).
So my question. Wich TAG Cache Modules i need in order to activate the cach‘ing function.
Reply 1 of 12, by majestyk
Do you have a picture where all cache sockets are visible?
Reply 2 of 12, by kawe-dus
majestyk wrote on 2022-08-05, 12:45:
Unfortionaly not 🙁
But i have a picture of the shematic. Maybe it helps ?
Otherwise i can disassmbly the computer in the evening so i can make better pictures.
Reply 3 of 12, by pancakepuppy
The board photo on UR shows U32, U33, and U42 (though I notice you don't have a socket there. Maybe that's for dirty bit?) populated with 20ns Logic L7C164 16k x 4 SRAMs. Similar parts are QS8888, P4C188, MT5C6404, CY7C164.
Reply 4 of 12, by majestyk
At the moment you have 128K cache in Bank 1. The 4 chips need to be put into Bank 0 if the documentation is correct:
The attachment 307_cache.JPG is no longer available
Second you probably will have to adjust the jumpering (red box)
The attachment 307_cache1.JPG is no longer available
Third the TAG chips U32 and U33 must be populated as "pancakepuppy" suggested.
Probably the board had 256K L2 cache plus TAG and someone pulled the 6 chips.
Reply 5 of 12, by kawe-dus
Ok thank you all very much for your help.
At this time it seems hard to find suitable chips here in germany.
Today i ordered 1 CY7C164-20PC
So i need to be patient until another chip are offered.
At the same time i ordered two chips with an higher refresh rate
IC CY7C164-35PC (so it shoud be 35ns)
Is it possible to use chips from different vendors if they are both 20ms or must both come from the same vendor or use the slower chips ?
Reply 6 of 12, by majestyk
The "higher refresh rate" actually means a slower memory chip. The nS value corresponds to frequency (f=1/t).
TAG RAM is generally allowed to be a step slower than L2 cache and some pictures show 25nS L2 chips so you could give the 35nS TAG-chips a try. It depends on the quality / selection of the chips you get. They might run stable or they might cause stability problems. With 20nS you´re on the safe side.
If your frontside-bus is 33 MHz this means 30.3 nS for the L2 cache chips -> 25nS chips are used
If your frontside-bus is 40 MHz this means 25 nS for the L2 cache chips -> 20 nS chips are used
As you can see slightly faster chips are being used to make sure tolerances don´t matter.
For TAG RAM I wouldn´t use 35nS chips at 40 MHz FSB, they might work at 33 MHz though.
Reply 7 of 12, by pentiumspeed
Actually other way around. The tag cache is specified to be 5ns faster than the main cache chips, I saw that in number of motherboard manuals. But at the point if cache is 15ns, the tag ram is still 15ns.
Cheers,
Great Northern aka Canada.
Reply 8 of 12, by majestyk
pentiumspeed wrote on 2022-08-06, 00:18:
Cheers,
A typical COAST stick for eyample has both L2 and TAG chips soldered in the factory.
The attachment l2_TAG_speed.jpg is no longer available
It´s for a maximum FSB of 66MHz so 6nS or 7nS L2 chips are present while the TAG chip has 15nS (sometimes 12nS).
This is also the case on countless mainboards.
The attachment ga586dx1.JPG is no longer available
Depending on the chipset there are several cache policies and methods to handle data in cache and TAG so maybe there are cases where both chips need to be made for the same frequency.
The L2 cache size necessary to cache a certain amount of RAM also differs between chipsets.
When I flip through my gallery I find several 486 mainboards with cache and TAG having the same speed like 20 or 15nS. I don´t know if these got fit in in the factory or if this was done to simplify production / sourcing.
But in many cases it looks like this:
The attachment FIC_486__cache.jpg is no longer available
The TAG chip has a slower speed than the L2 SRAM chips.
And I doubt that at this time (when 15 or 20nS chips were used for 486 boards) faster TAG chips with 7nS or 6nS were even available / possible to produce.
Reply 9 of 12, by rasz_pl
TAG speed dictates resulting latency, the slower it is the slower it takes for the chipset to look up if data is in cache
cache data chips speed translates to cache transfer speed
Reply 10 of 12, by majestyk
rasz_pl wrote on 2022-08-06, 15:58:
But obviously this doesn´t matter. If TAG latency was a bottleneck, manufacturers would have used TAG chips with the same or higher speed as the L2 chips.
They did not as I showed above.
Reply 11 of 12, by rasz_pl
some did, some didnt
counter example https://www.ultimateretro.net/en/motherboards/1111
Reply 12 of 12, by majestyk
That 12nS TAG schip was probably fit in by the same guy who screwed the screw of the heatsink - or 12nS 8Kx8 chips were cheaper / better available.
Later revisions of this BIOSTAR board with burst-SRAM had 15nS TAG chips (the Samsung "-13" chips are 7nS):
The attachment 8500TACv6.JPG is no longer available
Glad you picked a 430FX board.
The INTEL application notes have all the info about the timings:
The attachment 430FX_timings.JPG is no longer available
At no frequency are the TAG timings faster than the cache timings. They are slower and @ 66MHz equal.
(Same goes for the Burst SRAM case: All TAG timings are significantly slower.)
Here´s the full datasheet:
http://13.124.15.139/pdf/download.php?id=fd4b … =P&term=82437FX
___________________________________
Just for the record here´s another example, where TAG-RAM seems to be faster than cache-SRAM:
The attachment 12_15_cache1.JPG is no longer available
While the cache SRAMS do have 15nS read and write cycles, the TAG-chip - despite having "-12" in the name does in fact have 120nS read and write cycles!
