First post, by Kahenraz
I can see in a command prompt via SET that it is "COMSPEC=C:\COMMAND.COM". Where is this value being set?
Reply 1 of 3, by mr.cat
Did you ever figure it out?
I could be mistaken but it sure looks like the initial value is hard coded into IO.SYS, at offset 0xa75c.
But I suppose it may be altered in some later stage (via registry perhaps?)
Reply 2 of 3, by Kahenraz
It probably haa to be set somewhere during the boot process before COMMAND.COM gets loaded, so that's a good guess. I think that my IO.SYS was actually compressed and I'm guessing that I dropped this file into a hex editor years ago and had this question when I couldn't find it in the data.
Reply 3 of 3, by Grzyb
It can be altered by SHELL statement in CONFIG.SYS
Nie rzucim ziemi, skąd nasz root!
