First post, by gaffa2002
- Member
Hi everyone,
Just finishing a new PC build using a P200mmx I had lying around... it turns out that this CPU scales very well using setmul and its great for DOS games.
Unfortunately, when trying to play Soccer Kid on it I'm having a strange issue: The game seems normal (intro, menus), but when I get to the first level, the colors are all messed up, except for the player sprite and the ball.
The system I'm trying to run it:
-P200 MMX
-64mb RAM
-V72MA motherboard (ali chipset)
-Diamond Stealth 3D 2000 2mb PCI
-Ati Rage Pro Turbo (onboard)
-Aztech 6800w sound card
-Freedos 1.3
Things I already tried without success:
-Using different video cards (tried with both the onboard ATI and the Stealth 3D)
-Using a different monitor
-Using DOS 7 (so this is not freedos problem)
-Reducing CPU speed with setmul
-Tried running the game without sound
-Tried reducing available memory with himemx and by creating a ram drive.
Does anyone have any other ideas on what the problem might be?
LO-RES, HI-FUN
