First post, by Rikintosh
I'm thinking of building a core2 rig, as prices are currently very low (it's in what I call limbo, the moment when the hardware is too old to be useful in everyday life, but still too new to be of value to collectors). I would like to build a nice machine with nice things, I mean, not necessarily the top of the line from 2008, but that looks nice and different from the common one, whatever ddr2, ddr3, I intend to use a C2D E8400 or a C2Q X9650, but it needs to have PCI Express.
Any tips, thoughts?
Take a look at my blog: http://rikintosh.blogspot.com
My Youtube channel: https://www.youtube.com/channel/UCfRUbxkBmEihBEkIK32Hilg
Reply 1 of 4, by TrashPanda
Do you want to do SLI or Xfire ?
If not then what is your planned use case ?
I have a lot of 775 boards and just as many CPUs, if you want a nice easy Core2 Quad system then avoid the top end stuff and find a nice P45 board, Gigabyte boards are a plenty on eBay but I wouldnt go looking for one of the DDR3 models, a nice GA-EP45-UD3P would be a very nice solid board that wont break the bank and it also supports XFire, grab a pair of HD5850s, 4gb of DDR2 1066 memory and a X-Fi Sound Card and itll make for a very nice XP rig. If you want SLI then things get a little more complicated as you will want a SLI board unless you are willing to jump into the filthy world of hacked SLI drivers.
But for SLI a EVGA nForce 750i/780i motherboard with the above parts but two GTX280 cards will make for a good solid SLI rig, going SLI will actually cost more as both the motherboards and GPUs have the nVidia tax on them and from my experience dont make for nice budget 775 machines, but they are exceptionally powerful machines if you are willing to throw cash at them. I have a QX9770 SLI GTX295 rig and its a monster that well .. cost far more than I would have liked 🤣, the motherboard was the hardest bit to get as ASUS Striker II extreme boards are rather rare on eBay. (I dont recommend a build like this)
If you dont want either SLI or Xfire then things get a bit cheaper as you can just use the above GA-EP45-UD3P with whatever brand GPU you like and itll work wonderfully with either CPU you choose, I still recommend 4gb of 1066 ram as there is no reason to not use the full amount XP32 can address, of course with 4gb you could even throw Windows 7 on it as dual boot.
If you are wondering why I went with Gigabyte here its because Gigabyte has been great at leaving up all their legacy drivers and bios updates which makes it super easy to find them but if you have other preferences then make sure you can get the latest drivers for the boards before you buy it, its a pain in the ass trying to setup a new system only to find you now have to spend hours hunting down drivers because the fab took them down.
349.28 KiB
EP45-UD3P
Not sure if you agree but the GA-EP45-UD3P is a great looking board while having a huge amount of IO and PCIe slots.
Reply 2 of 4, by Rikintosh
TrashPanda wrote on 2022-08-11, 02:21:
Do you want to do SLI or Xfire ? If not then what is your planned use case ? […]
I don't plan on using SLI or Xfire (although I don't rule it out). I live in Brazil, so I have little choice, I'm limited by what's available on the market at a fair price.
I was thinking of using some more sophisticated graphics card instead of using a couple of graphics cards, for example a 3870, 4870, or 9800GTX maybe...
Whatever it is, it will go for a big standard-atx case, as I don't like micro-atx and smaller cases (at least, not for games this generation). It would be a machine for Vista/Seven generation, because I already have one for the end of the XP era (late 2006, P4 3.8ghz). I was thinking of a machine to play BioShock, FarCry 2, Crysis... In the past I had a nice motherboard, which had an xfi sound blaster onboard or something, I think it was an asus formula, but there was a rain, lightning struck my house and completely fried my entire rig, including two 8800GTX. I remember that I still hadn't finished paying for it and didn't have the money to buy it all again, so I survived for a long time using a Dual Core 1.6, with a simple gigabyte 945 motherboard that only had agp slot, I I had found the radeon 4650 in the AGP version, which had a lower performance than the PCI-E version, but at least I managed to beat GTA IV... Hard times create strong men 🤣
Reply 3 of 4, by Sphere478
Core 2 quad for the win!
One of my modern computers is a c2q
Sphere's PCB projects.
Reply 4 of 4, by TrashPanda
Rikintosh wrote on 2022-08-11, 03:07:
I don't plan on using SLI or Xfire (although I don't rule it out). I live in Brazil, so I have little choice, I'm limited by wha […]
Brasil does make it difficult for tech heads, that tariff on imported tech products is a pain in the arse, it also makes it difficult to give advice but I think seeing what's available and then basing your build on that might be the way to go. P35, P45, G31, G41 are some nice options if you can find them, you might even get lucky and find a X38/X48 board locally, if its cheap enough I would grab that.
