First post, by Joosemachine
Hi all,
I was hoping someone might be able to help me locate a packet driver (for use with mTCP in DOS) for this network card. I plugged it into my win98 machine and it identified it as a SMC Ethercard Elite16 Ultra 8216t ISA (say that 10 times and stay fashionable!), which seems to be consistent with the sticker on the back of the card. I have been looking everywhere for about a week, and have found some drivers, but none seem to detect the card or work with it. The closest I got was an application called EZSTART from an .iso of SMC drivers which I found (maybe from archive.org?) which correctly detected the card etc, but when I went to the menu option to install the packet driver, it just pointed me to the SMC website (which obviously no longer exists), so I am stuck again.. Has anyone used this card in DOS or know where I can get a driver for it?
thanks in advance for any replies!
Reply 1 of 6, by zyga64
I have similar card (combo with BNC and AUI connectors in addition to 8P8C for twisted pair ethernet) which is working fine in my 486DX33 rig.
I'm using this driver (in attachment).
8088@8 /640k /TVGA9000C /ALS100+TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 2 of 6, by davidrg
I've got a bunch of Elite16 drivers archived here (along with a scan of the manual):
https://ftp.zx.net.nz/pub/drivers/SMC/Elite16/
There are two versions of ether.exe in there - one from 2000-07-14 which should be the latest, and one (in the 'old' subdirectory) from some time in 1996. Version 11.5 of the packet driver (gpk115.exe) dated 1996-06-22 is also there - probably ether.exe has a newer version.
SMC drivers seem to be relatively universal - they just have one driver that worked for all their cards which is what the ether.exe package contains. Though back when I was trying to network boot Windows 95 with an SMC card I had issues with some versions of the (ODI) driver and, IIRC, ended up downgrading to the older version.
Reply 3 of 6, by devius
For what it's worth I successfully used a packet driver with a filename pkt8000.com with a slightly older SMC EtherCard Plus Elite 16C also with mTCP. You will probably find it in one of the files that others shared, but if not, I can provide it.
Retro Coisas no YouTube
Reply 5 of 6, by Grzyb
PKT8000 11.60 is sure to work.
In case of problems, have a look at this topic - SMC (WD) StarCard PLUS (WD/8003S) Win3.1?
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 6 of 6, by Joosemachine
wow! thanks so much for the replies everyone! I'll try out all of the suggestions, I'm sure one will get me sorted!
