First post, by lukas12p
Hello
I'm looking for a BIOS file for Asus AGP-V7700 TVR 32M AGP NVIDIA GeForce2 GTS
Card doesn't work with most of my tested systems, where other GF2 cards work, so I want to compare BIOS with original file.
My BIOS is 3.15.00.12.31.
I have found one, but older, so can't compare
Reply 1 of 4, by xpladv570
Here is a BIOS i dumped from my own GF2 V7700.
It is older than the one you have, but you should try flashing it and see if it helps you.
Rename extension .h to .ROM.
Reply 2 of 4, by mockingbird
lukas12p wrote on 2022-08-12, 15:00:
Hello
I've been there... I think I concluded that the RAM must be defective somehow... And I have the 64MB version.
(Decommissioned:)
Reply 3 of 4, by lukas12p
Could be ram problem, card works in DOS on i815
After installing Win98 driver screen corrupts and after restart windows won't boot.
Reply 4 of 4, by xpladv570
Sure does look like a bad card, that is unfortunate.
