First post, by Smucek
Hello guys 😀
I have the card mentioned at subject 12 MB version, and wierdly, 8 memory chips are rated at 83 MHz, and all others are at 100 MHz.
I have paired it in SLI with Dragon II Voodoo 2 12 MB, which has all memory chips rated at 100 MHz.
I am using fastvoodoo 4.6 drivers (default).
Am I hurting the 83 MHz chips? Or the both cards are working on 83 MHz?
I have read somewhere that fastvoodoo 4.6 drivers overclock memory to 93 MHz, is that true?
Any advice is welcome 😀
Reply 1 of 3, by imi
Smucek wrote on 2022-08-13, 11:14:
yes, you can open the OC panel and turn it back to 90, or 83 I guess for the slower memory.
Reply 2 of 3, by Smucek
imi wrote on 2022-08-13, 12:43:
Thanks for fast reply.
Where is OC panel, i don't have any.
Reply 3 of 3, by imi
where you installed the FastVoodoo driver, under ...\Tools\Tweaker\V2_OC
after you run it you should have the panel in the display properties
