First post, by HangarAte2nds!
I will be building a VLB 486 in the near future and plan to use a modern PSU. On a 500W ATX power supply, 120W are split between the 3.3V and 5V rails. Since it is VLB, the board only gets 5V and 12V. Some 3.3V may be used by drives but it would be small since that voltage is only used for signaling. The CPU itself runs on 3.3V but via a voltage regulator fed 5 volts. My gut says that 120W split between 3.3 and 5V would be sufficient for any 486 build and probably a Pentium as well. The amount of 12V power available is closer to 400W and that is definitely not a concern. Can anyone confirm the soundness of my assumption with experience? I would hate to end up chasing my tail over an electrical supply issue if there is some potential problem.
I seem to remember I had like an 80W PSU when I built my first PC back in the day, also for a 486...
Reply 1 of 10, by TrashPanda
Most AT power supplies are 150 - 230watts but the system board itself wont use any where near that, what's important is -5v which you wont get with a modern PSU unless you use something like a Voltage Blaster to add the -5v to the ISA bus.
You can find Voltage Blasters on eBay for pretty cheap so it wont be much of an issue but most 486 era sound cards wanted -5v to work, the other thing to be aware of is the +5v Amps, I doubt a modern PSU is going to have issues here with a 486/Pentium class machine but its something to be aware of that you want as many AMPs on the +5v rail as you can find.
Reply 2 of 10, by bloodem
TrashPanda wrote on 2022-08-14, 13:20:
[...] what's important is -5v [...]
It's really not (unless you want to use one of the very few cards that need it - such as a SB 2.0). 😀
[...]but most 486 era sound cards wanted -5v to work[...]
Most? The only one I know of is SB 2.0. Earlier (SB 1.5) and subsequent sound blasters work just fine without it.
In fact, it's very easy to tell if you need it. Check the card's pins. If the -5V pin (on the back of the card --> 5th pin from the left) has a trace that leads somewhere, then -5V is needed, otherwise no.
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 4 of 10, by TrashPanda
bloodem wrote on 2022-08-14, 13:38:
Well I guess you could use a different sound card that doesnt need it.
Reply 5 of 10, by bloodem
TrashPanda wrote on 2022-08-14, 13:40:
You'd definitely want to use a card that doesn't need it, because SB 2.0 (the only card I've ever tested that actually needs -5V) is not really suitable for a 486 (or even a 386).
A 486 works very well with a SB Pro 2 or even a SB16 (or other equivalent cards), and those don't need -5V at all.
Regarding power, all modern power supplies that I've tested worked just fine with a 486. Total power consumption (at the wall) is ~ 30W or less.
In fact, all (good quality) modern power supplies work fine with most old hardware except for fast Athlon/Athlon XP builds - those that don't have the CPU ("P4") connector.
Reply 6 of 10, by TrashPanda
bloodem wrote on 2022-08-14, 13:47:
You'd definitely want to use a card that doesn't need it, because SB 2.0 (the only card I've ever tested that actually needs -5V […]
I was thinking more along the lines that if you are building a 486 then its possible OP has ideas to play around with hardware from that era, I know if I had a nice 486 Id definitely want to check out the likes of Adlib and such which does want -5v, so yes its not a "need" but rather nice to have, its why I suggested a Voltage Blaster since there is no other easy way of getting it from a modern PSU.
Reply 7 of 10, by bloodem
TrashPanda wrote on 2022-08-14, 13:55:
The Adlib does not need -5V. It's missing the -5V pin completely. 😀
The voltage blaster is great (I've also built a few myself), but I only use it with SB 2.0, since, out of all my 300+ sound cards, this is the only one that needs -5V. 😁
PS: the Adlib Gold doesn't need -5V either (not that we'd care, since most of us will never have that card 😁 ).
Just in case anyone has doubts, this is the back of the Adlib card, and the missing pin (circled in red) would've been the -5V pin.
Some cards do have the pin (but without having any trace). Obviously, those don't need -5V either.
    1.87 MiB
Reply 8 of 10, by TrashPanda
bloodem wrote on 2022-08-14, 13:58:
The Adlib does not need -5V. It's missing the -5V pin completely. :-) The voltage blaster is great (I've also built a few myself […]
Hmm the few models I've seen do have that pin, not that I ever had the presence of mind to check the traces for it.
Mind you Adlib is pretty rare around my parts so I haven't seen a lot of models in the flesh.
The question then is ..why was the -5v line enough of an issue to bother designing a Voltage Blaster, surely it was not because of that one sound card.
Reply 9 of 10, by Horun
Most Media Vision PAS, PAS16, etc need -5v, for the audio amps iirc
Reply 10 of 10, by bloodem
Horun wrote on 2022-08-14, 14:22:
Yes, the PAS cards I've seen do need -5V (don't own any, though).
But then again, those aren't really cards that non-collectors would want in their retro PCs.
