First post, by Almoststew1990
I am having a clear out of retro stuffs. Which video card would you keep for occasional use in a 486 PC?
S3 Trio64V+ PCI
ATI Mach64 (ct version...?) PCI
STB Lightspeed 128 PCI
Trident 900C ISA
Realtek RTG3105 ISA
Only for DOS gaming so I guess from a compatibility / image quality perspective.
Reply 1 of 6, by Meatball
S3 Trio64V+
Reply 2 of 6, by imi
for compatibility the S3 Trio, but I'd definitely keep the STB Lightspeed 128 for coolness factor :p
Reply 3 of 6, by acl
Just for my curiosity , what's wrong with the Mach64 CT ?
I'm using one (Upgraded to 2MB) for my late DOS machine with a Voodoo.
But i never really thought about using another one. (that, and also because i'm an ATI fan)
I have a Trio64V2DX waiting in a box and a Matrox MGA-2064W / IS-STORM comming soon...
Reply 4 of 6, by Meatball
acl wrote on 2022-08-16, 15:28:
Just for my curiosity , what's wrong with the Mach64 CT ? I'm using one (Upgraded to 2MB) for my late DOS machine with a Voodoo. […]
Beside all the problems listed with ATI for DOS games here: https://gona.mactar.hu/DOS_TESTS, none of the ATI cards I have tried can play 'Terminator: SkyNET' or 'Future Shock' (with the upgrade) in 640x480 resolution. It's no problem for Trident, S3, and 3dfx, however. If you don't play any of the games listed, you're probably fine. At this point, I don't give ATI cards for DOS a 2nd look.
This doesn't mean I don't like ATI cards (from 1995 - 2002), I only wouldn't use them for my DOS needs when there are more consistently performing options available.
Reply 5 of 6, by acl
Thank you for the details. That makes sense.
And thanks for the link, very interesting !
Edit : Actually, very surprised by the Intel i740 results. It's a quite good in DOS.
Reply 6 of 6, by Grzyb
STB Lightspeed 128 = Tseng Labs ET6000, definitely the best of them all.
But I would rather use it with a Pentium, coupled with some Voodoo.
For a 486 with pure DOS, S3 Trio indeed seems to be the perfect match.
Kiełbasa smakuje najlepiej, gdy przysmażysz ją laserem!
