dosbox fc4 gcc4 x86_64
First post, by awjb
Hi,
I am the package maintainer for dosbox at fedora extras. As FC4 is right around the corner I wanted to get dosbox build on all supported archs (i386,ppc,x86_64). While the first two did not pose any problems x86_64 was a little bit more trouble. Attached is my patch against 0.63 release. Maybe some of the changes can in some or another way be integrated into the next version. The will compile fine on i386 and ppc two.
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
there is a special fix for a file issue in the cvs as well. (64 bit only)
I think it's in src/dos/dos_files.cpp
most of your lines are in the cvs allready
not sure about the midi thingie
Water flows down the stream
Reply 3 of 4, by awjb
Ok thanks for the heads up 😀
Reply 4 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
your welcome. Thank you for the patch.
