First post, by Strahssis
Hi there,
I have been looking into obtaining a Casio LD-50 drum module, because they can be found for quiet reasonable prices. I read online that the LD-50 is based on the Dream SAM9793 chip, so I was thinking: if I wire a DIN-5 to the MIDI-IN pin of the chip, would I be able to use the drum module as a GM-module? I ask prior to buying before I buy a clunky device I may have no use for. Thanks in advance! 😜
All the best,
Strahssis
Mimi: AMD K6-2/266, S3 Trio64, Diamond Monster 3D II, Sound Blaster CT2800, 32MB RAM
Satellite 220CS: Pentium 133, SVGA DSTN, Sound Blaster Pro, 64MB RAM
Contura 420CX: 486DX4 75, VGA TFT, Roland Serial MIDI, 16MB RAM
Reply 1 of 1, by DevanWolf
Refer to service manual for LD-50 and also datasheet for SAM9793.
Wire in a MIDI opto-isolator to pin 98 (MIDI IN) of the SAM9793.
And for MIDI OUT, wire pin 13 of the MCU (87C58UBA) to grounded DIN or 3.5mm TS jack + a toggle switch for local control or MIDI output select between internal synth and external device.
Otherwise, get a product that uses the much later SAM2695 (smallest General MIDI synthesizer chip which uses the same soundbank as SAM9773/SAM9793) such as MIDI-Guy or DreamBlaster S2.
