First post, by shimart
I made it. nano8088
https://github.com/monotech/Nano8088
(Based From https://github.com/skiselev/micro_8088)
391.62 KiB
I don't have electronic knowledge, but I'm happily building a retro machine while recalling my childhood memories.
Thank you very much for sharing and dedicating your open source PC hardware project.
I successfully completed NANO 8088 about half of the time, but the error message below makes me sad.
281.54 KiB
150.27 KiB
I made it as below, is there any problem?
Replace with PN2222 => 2N2222
Replace with Faraday FE2010A => Proton PT8010AF
Install 6.5-30 pF trimmer capacitor as unclear product
Or, Is one of the AS6C4008 (SRAM) broken?
Please give me some advice.
Thx!
Reply 2 of 5, by shimart
and, MAXDOS run. (UMB)
179.51 KiB
567.16 KiB
RAM Check error message is output.
But UMB seems to be doing well.
509.56 KiB
Reply 5 of 5, by C0op3r
Well I have been trying to buy a set for 2 weeks - had a friend in Korea msg you and everything but no luck.
So I ended up ordering all the parts to build my own - really wish I could of picked up a set from you.
Cooper
