First post, by gaffa2002
- Member
Hi,
Many years ago I bought the game Primal Rage and at the time I was able to crack it to run without the CD. I used to have this cracked executable for a long time but unfortunately I lost it.
Does anyone knows a place to download the crack or the cracked exe? Only thing I found was some manual steps for cracking using an hex editor, but it didn't work for me. To make things worse, there are three different versions of the game (4,8 and 16mb versions) and each has a different executable.
With dosbox there is no problem as I can just mount the CD image, but on real hardware It's quite annoying having to insert the CD to play as it doesn't add anything to the game.
Btw I always install the 16mb version.
Thanks in advance
LO-RES, HI-FUN
