What is SELINFO?
First post, by zhangyan
I tried both the debug and the Heavy-Debug mode of DOSBox.
I simply want to dump the data segment, but I don't know where the data segment starts and where it ends.
So, I tried the SELINFO command.
From the help file,
SELINFO CS/DS/ES/FS/GS/SS/[seg] returns information about the descriptor of the segment the given register is currently pointing on. You can also specifiy an arbitrary segment using a hex value.
My command was:
SELINFO DS
I hoped this command could tell me the position and the length of the data segment, but there was no message shown.
Did I make something wrong?
Actually, I didn't quite understand the descriptions of SELINFO, what kind of information it is supposed to provide?
Thanks in advance.
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
selinfo is used in protected mode.
then segments are handled differently
Water flows down the stream
