First post, by danieljm
Hey all,
I seem to be having the same problem as others have had with some Asus boards. See here: P3B-F PS/2 ports stopped working
It's the exact same issues. 2 different PS/2 mice aren't detected in Windows or DOS. And if I go into the BIOS, the PS/2 keyboard stops responding. Keyboard usually works outside of the BIOS but not always. And the issues go away if I unplug the mouse.
The solution for the Asus board seems to be removing a capacitor. Anyone have an idea if a similar procedure could be applied to the BH6?
Thanks!
Reply 1 of 4, by PcBytes
Kinda in the same boat as you but with a Acorp 6VIA81P (VIA 693A/596B) that I am trying to restore.
The issue on mine though kinda resembles the P3B-F, but so far I haven't removed any of the KB/Mouse caps since I'd rather wait along with you for a fix on this.
Reply 2 of 4, by danieljm
Well, I'm glad to see I'm not alone in this. 😀
Reply 3 of 4, by rasz_pl
start by taking the board out and inspecting it thoroughly near PS2 ports. That asus post suggests a spill on the motherboard and cracked/shorted capacitor as a result.
Reply 4 of 4, by danieljm
So, I think I solved my problem and it ended up being dead simple.
I decided to prod at it with my multimeter again to see if I could find anything I missed before. When I checked one of the fuses near the PS/2 ports I think I poked it on the side this time instead of pressing down on it, which made the fuse easily lift off the board on one side! Thankfully I didn’t do any damage on the side that was still soldered to the board. So I soldered it back down and everything seems to be acting normal.
So I guess I never found the problem before because I would have pressed down on both sides of the fuse and got a good reading on the multimeter. Lesson for the future would be to check continuity across a longer distance.
I’m still surprised by the symptoms I had with the keyboard not working sometimes and that sort of thing, but I’m not going to worry about it now. 😀
