First post, by Jixop
hi
ok
I'm working on WinXP (with p4 1.7Ghz en radeon 9800pro but i think that doesn't matter)
Ive downloaded the game Wrom:
http://les.bat.pages.free.fr/Pages/fun/jeux/dstroy/ds.html
Then I installed it
started DOSBox, mounted it, and started it.
I got a configuration screen and i changed the soundsetting and it worked!!! I got music.
then entered the game and the logo started playing with music. after that IO got an error.
"Exit to error: Pagefault didn't correct table"
and then DOSBox shut down with the game.
I tried again just plaing under winXP It worked playing, passing the logo and all but i don't have any sound!
So what could be the problem? or is there a solution?
(ps are the makers dutch people because I got sent to a dutch info page (about the date) when registering?)
THx in advance
bye
Jixop
Reply 1 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
are you using 0.63 ?
what do you mean with a dutch info page ?
maybe the server detects your local settings ?
Water flows down the stream
Reply 2 of 6, by Jixop
yes I'm using 0.63
have you tested the game? please do so I know if the problem is with my pc?
I see you're an author, where can I post Ideas to improve DOSBox? (save settings or easy to mount the same folder when starting DOSBox again, and others)
dutch info page: http://www.php.net/date
Reply 3 of 6, by Jixop
anybody?
does anyone tested DStroy yet? I really want to play it with sound!
pretty plz
thx in advance (again)
bye
Jixop
..for that thing about saving setting and stuff i foudn what to fill in the shortcut so it does it automatically.
Reply 4 of 6, by MiniMax
Rank Moderator
Moderator
Hmm - seems to be YAGTOWW061 (Yet Another Game That Only Works With 0.61).
Jixop, download DOSBox 0.61 and install it on your computer.
Here is the dosbox.conf I used:
# DOSBox 0.61 configuration for "Dstroy 1.2"
# (http://les.bat.pages.free.fr/Pages/fun/jeux/dstroy/ds.html)
# By MiniMax
# OBS: Dstroy 1.2 does *NOT* work with DOSBox 0.62 or higher. Use DOSBox 0.61.
# Download DOSBox 0.61 here:
# http://sourceforge.net/project/
# showfiles.php?group_id=52551&package_id=46709&release_id=214628
[cpu]
core=dynamic
cycles=14000
[render]
frameskip=1
[autoexec]
@ echo off
mount C "C-drive"
mount D "Unzipped"
D:
if exist C:\Dstroy\DS.Exe C:
if exist C:\Dstroy\DS.Exe cd \Dstroy
if exist C:\Dstroy\DS.Exe echo Type DS to start the game.
echo on
_________________
Reply 5 of 6, by Jixop
thx mate, besides some stuttering in the menu it all works perfectly!!!
Reply 6 of 6, by MiniMax
Rank Moderator
Moderator
Try lowering the CPU cycles (cycles=8000).
_________________
