First post, by AppleSauce
Does anyone know what the drive mode selector jumper does?
46.65 KiB
Reply 1 of 10, by AppleSauce
Right well I half figured it out , the single bit overrides the drive to be the only recognized drive on that header.
No idea what the factory bit means though.
Reply 3 of 10, by Ydee
Master/Slave/Cable select are jumpers in "Jumper Block", I think. This single jumper is designed for configuration where there is only one IDE/ATA device on the cable (that is, this CD ROM drive). Some HDDs had it too.
Reply 6 of 10, by Horun
I have a Liteon 32x, a NEC cd burner, and some others with those extra 3 jumps and look nearly identical in back, AFAIK you do not use those for standard PC setups.
Factory is for a final test/calibration of the drive and that Single drive is for a specific use, Apple possibly or upgrade flashing the rom in a multi CD setup to make sure that just one gets flashed) iirc
(been a long time since I even thought about those so am probably remembering wrong from decades ago..)
If you look at many early PC cd burners you will see a space for those same jumpers but they are not there because they were not for "end users" ;p
just rambling...
Reply 7 of 10, by AppleSauce
dionb wrote on 2022-09-21, 07:42:
That's a quite inventive set of jumpers. Which brand/model drive is this?
It's a NEC CDR 273
https://stason.org/TULARC/pc/optical-cd-drive … OM-CDR-273.html
147.2 KiB
Reply 8 of 10, by AppleSauce
Horun wrote on 2022-09-22, 03:27:
I have a Liteon 32x, a NEC cd burner, and some others with those extra 3 jumps and look nearly identical in back, AFAIK you do […]
just rambling...
That's really odd , you'd think they wouldn't leave that kind of stuff exposed for consumers or at least hide it somewhere inside the drive on the pcb.
Reply 9 of 10, by Ydee
You can see this on some old HDD´s too, it´s really for configuration, where only this device alone is connected on the cable:
    188.3 KiB
Reply 10 of 10, by AppleSauce
Ydee wrote on 2022-09-24, 16:41:
Yeah the single thing makes sense , its more the factory setting that's a bit odd.
