First post, by slivercr
Hey vogons, I need help to see if I can fix a motherboard.
The problem is it has stopped working with AGP cards. That's it. It was working fine, then one day I lost video. The board had been recapped and cleaned like 3 years prior to the failure, and it had run smoothly until then.
Things I've noticed since then:
  • It will not boot with the following AGP cards (I'll get no video and the card's fan will not even spin)
    • Geforce2 GTS
    • Geforce3
    • Radeon 8500
    • Geforce FX 5500
    • Radeon 9700
  • It boots fine with PCI video cards.
  • It boots fine with an AGP Voodoo3, this really surprised me.
I always hear how "Voodoo3 and Voodoo5 are not real AGP cards", this really drove it home. I suspect either some failing power rail or some AGP initialization routine, but I haven't really started digging.
Any ideas as to where to start? Any help will be appreciated.
Outrigger: an ongoing adventure with the OR840
QuForce FX 5800: turn your Quadro into a GeForce
Reply 2 of 11, by slivercr
pentiumspeed wrote on 2022-09-21, 23:16:
Check CMOS battery or change it. Reset the CMOS settings too.
Cheers,
Already changed the battery and reflashed the BIOS. Didnt help.
Reply 3 of 11, by Namrok
Once I had that problem. Turned out to be my ram. Why would that cause all agp cards to stop working? I assume it's because agp apatures use ram as extra agp vram. But I could be wrong.
Win95/DOS 7.1 - P233 MMX (@2.5 x 100 FSB), Diamond Viper V330 AGP, SB16 CT2800
Win98 - K6-2+ 500, GF2 MX, SB AWE 64 CT4500, SBLive CT4780
Win98 - Pentium III 1000, GF2 GTS, SBLive CT4760
WinXP - Athlon 64 3200+, GF 7800 GS, Audigy 2 ZS
Reply 4 of 11, by slivercr
Namrok wrote on 2022-09-21, 23:47:
Will try a few different sticks of RAM and report back.
Reply 6 of 11, by slivercr
slivercr wrote on 2022-09-21, 23:58:
No luck—tried all the RAM I had, in different configs. Same deal.
maestro wrote on 2022-09-22, 00:13:
Another clue might be that those are 3.3V only cards while the others (i think) are 1.5V capable. Maybe try another 3.3V only card and see if that works?
I thought about this previously, but I have no other "real" 3.3V card to test.
What I did was I faked a 3.3V card by grabbing an old Geforce2 MX and making a small cut to the A2 pin. This sets the card in AGP 2x, so supposedly 3.3V.
I had no luck with that, I'll try to find a real 3.3V AGP card to test out.
EDIT: I guess this is a flawed test, since the card will run at 2x but still at 1.5V. Will make a point to find another 3.3V card.
Reply 7 of 11, by maestro
slivercr wrote on 2022-09-22, 00:34:
I thought about this previously, but I have no other "real" 3.3V card to test. What I did was I faked a 3.3V card by grabbing an […]
It's just an observation, whether it leads somewhere useful is another matter. I also think you're right about the GF2 MX still at 1.5V.
BTW I love your OR840 thread and I'm a big fan of your work. I have two OR840's, a 606 and a 701 revision. The 701 will run 512MB RIMMs but the 606 wont. I think the 701 needs to be recapped, it used to run fine on 4xRIMMS but it has become unstable. It's better on 2xRIMM/2xCRIMM but not 100% stable. I hope it's just a recap. The 701 is pimped with two SL4BS P3's and it's my favourite Voodoo5 board.
81.24 KiB
Reply 8 of 11, by slivercr
maestro wrote on 2022-09-22, 01:09:
Thanks for bringing it up, made me think about it.
I'll try to find a TNT—I must have one somewhere—and try out. If the TNT and the Voodoo3 work then its probably just be the 1.5V generation, so a dead MOSFET or something like that
Thank you! Glad to see more OR840 users out there… there's dozens of us, dozens!
Have you tried recapping the 606? User doogie had a revision which wasnt compatible with 512MB RIMMs and the only difference seemed to be 270uF caps instead of 470uF caps used in later revisions. I guess what I'm saying is: if you're thinking about recapping one, do them both 🤣
Reply 9 of 11, by maestro
slivercr wrote on 2022-09-22, 01:25:
Ha, dozens.
No way! Well I'm definitely recapping both then, thanks for that heads up! I'll probably try doing it myself but I don't have any experience, so I have a few boards that I intend to practice recapping before I try an Avenger. I have my eye on an AM2 with bulging capacitors that previously booted but now it doesn't, I think a recap will resurrect it. Man, I wish I had a solder vacuum, maybe I'll look into a cheap one.
Reply 10 of 11, by dionb
Which board are we talking about here? An OR840 or something else?
If you can't find a 3.3V AGP card, you could work the other way round: stick in a 1.5V card and check on a measuring point on the card whether "1.5V" is within spec.
Reply 11 of 11, by slivercr
dionb wrote on 2022-09-22, 08:09:
Yeah, yesterday after maestro's input and me realizing my mistake with the GF2MX test I figured I might as well remove the board from its case and start measuring properly.
I'll check later today and report back. If the 1.5V signaling is failing, then there are a couple possibilities to look into
- Either the VRM generating 1.5V has failed, or
- the switching circuit from 3.3V to 1.5V is failing.
- Or I guess AGP's VREF could also be failing?
These are my uninformed guesses from looking at AGPs pinout, so input is welcome and appreciated!
