First post, by danieljm
My 8MB Creative Voodoo 2 has Silicon Magic chips on it (SM81C256K16CJ-25 for reference) and I'd like to do the upgrade to 12MB.
The only place online that I can find them is Alibaba which I've never used before, and it feels kinda sketchy. The 2 suppliers I've talked to have really jerked me around on the price. One of them is finally down to something I would consider reasonable, but it's a minimum order of 100 pieces, so I'm still looking at spending close to $100. My thinking is that I could probably sell the rest to other potential upgraders so that it would make more sense.
So I guess I'm wondering what people think. Anyone care to share good/bad experiences? Is there much risk of getting screwed over?
Thanks!
Reply 2 of 13, by mkarcher
danieljm wrote on 2022-09-30, 17:25:
Equivalent part (256K x 16 EDO RAM, 5V, Dual CAS, 25ns RAS access time, 10ns EDO page mode cycle time): Mosel Vitelic V53C16258HK-25, just for reference if sourcing the SM parts turns out problematic.
Reply 3 of 13, by Thermalwrong
Personally I wouldn't use Alibaba, the price is too likely to change and you need to order too great a quantity. It's just murky waters from what I've seen, my preference is to stick to Aliexpress to Ebay where a fixed price is agreed at the point of sale.
I've successfully put an 8MB Voodoo II up to 12MB by adding some SOJ ram chips: Re: Voodoo2 8 to 12MB RAM upgrade - is it really that straightforward?
The ones I bought were afaik from this seller: https://www.ebay.com/itm/255079057471
It's been a few years and the price is really about the same. It should be around $16, not $100 (albeit for 10x not 100x). Reselling them is more work that it's worth from my POV. There are few Voodoo II cards left and even less that people are willing to modify.
Reply 4 of 13, by darry
Sphere478 wrote on 2022-09-30, 17:27:
I’d be curious to upgrade mine to 24mb. If anyone has info on this.
Have a look here : https://darwin-3dfx.sourceforge.net/voodoo2.pdf
· 2 or 4 MBytes of SGRAM* or SDRAM* frame buffer memory
· 2, 4, 8, or 16 MBytes of SGRAM* or SDRAM* texture memory
That being said, I don't know how accurate that is as the Voodoo 2 used EDO DRAM, AFAIK, which is not even mentioned in this document .
Source : Voodoo2 16mb do they exist?
Reply 5 of 13, by mkarcher
darry wrote on 2022-10-01, 05:27:
Have a look here : https://darwin-3dfx.sourceforge.net/voodoo2.pdf · 2 or 4 MBytes of SGRAM* or SDRAM* frame buffer memory · 2, […]
Also from that document
Voodoo2 preliminary documentation wrote:
Important Note: Throughout this document, features, descriptions, and specifications which are marked with the * symbol are not present in the Alpha version of the Voodoo2 Graphics chipset.
So it seems like the SDRAM/SGRAM interface has been cancelled and the old EDO interface inherited from the Voodoo Graphics has been kept in place instead.
Reply 6 of 13, by danieljm
@Thermalwrong
I hadn't spotted those chips before, so thanks for pointing them out. I'd seen that post of yours before, but I never thought to spy the model number on the chips in your pics. 😀
And that price is so much more appealing. Now I just need to decide if savings will offset the OCD triggering that will occur by having 2 types of chips on the same card. 😁
Reply 7 of 13, by keropi
well alibaba is the aliexpress section for company/retailers purchasing in bulk
sellers will bend the rules and sell to individuals if a large enough quantity is agreed and if you are comfortable ordering from aliexpress then alibaba is no different
ask photos of the ram chips before you get them, sometimes fishy/fakes can be spotted from them
🎵 🎧 SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 8 of 13, by pentiumspeed
I purchased one item a month ago, a specific high rpm small blower fan made by ebmpapst, a german made item, intended for CPAP that as shown on their aliexpress and I got generic blower fan but totally different, yet good quality, that's not inspiring about their conduct of business. This is my first dipping the water. The page you want to buy does not have easy access to contact about this item in question. You have to find their message link on their store main of their products, (not on same page), and copy and paste about the item in question to confirm it is correct one etc and waiting for their replies, and it is not email either. More foot work.
Needed the ebmpapst since this is quality part planned to investigate the noise level at sufficient rpm to generate just enough PSI needed.
The search function to search for items you want to look at is not specific, and mostly generic quality, rarely industrial that you don't want (too big or specialized). In fact, generated lot of general items that is way off, forcing you to spend hours looking pages of pages to find few you want.
Most of them I have seen is usually accessible on ebay and more reliable.
Cheers,
Great Northern aka Canada.
Reply 9 of 13, by Omarkoman
Didnt want to create a new thread so I thought I'll post here.
I did bit of googling trying to locate the ram chips to upgrade my Diamond Voodoo 3D II from 8MB to 12MB but really struggling to find anything.
Any suggestions where to look or shop recommendation that stocks these that doesnt pop up on google easily ?
my card has SM81C256K16CJ-25 chips and I need TSOP format for the rear.
Thanks in advance.
Reply 10 of 13, by havli
If you don't mind different brand of the memory chips, these will work. https://www.aliexpress.com/item/1005005591453578.html
I used exactly these to upgrade my Voodoo1 from 4MB to 8MB. There were empty spots on the PCB 😀
Reply 11 of 13, by Omarkoman
havli wrote on 2026-02-04, 22:21:
thanks but I dont think these chips would work ? Googling these it says they are SDRAM and my V2 needs EDO ram chips ?
Also those are TSOP54 vs I need TSOP40
Reply 12 of 13, by Imperious
They are EDO ram. Read the datasheet. https://www.alldatasheet.com/datasheet-pdf/do … 16256A-25J.html
Reply 13 of 13, by Omarkoman
My apologies, I read it wrong including the package.
I placed an order, thank you for the link!!!
