First post, by tony359
- Oldbie
Hello all
I’ve recently got a CF to IDE adaptor, I understand CF are the best for compatibility as they just use IDE format so the adaptor is passive (my SD adaptor was a hit and Miss indeed).
I’m trying to have my card to work with all my systems: more recent socket 7 ones but also 286 and 386.
The card I think I have is a 2GB. What is the best procedure to have the best compatibility throughout the various systems?
I guess maybe installing it on a more recent system where the card can be auto-detected then fdisk it and format it. Then write down the cylinder/heads value for when using with older systems.
Would that work in your opinion? Is 2GB ok for an old msdos 6.22 and a, say, 286 system?
Thank you!
My Youtube channel: https://www.youtube.com/@tony359
